Two Quick Questions
Old Sep 2, 2017 | 11:45 AM
Northshore3lt's Avatar
Northshore3lt
Default Two Quick Questions
Hi,searched all over,can't find any info ☹️What is this attached to windshield?It is hard wired.
Also,any ideas to remove spots/film ( looks like maybe protectant overspray)from rear view mirror?
Tried glass cleaner no luck.
Old Sep 2, 2017 | 11:49 AM
Dragon Tamer's Avatar
Dragon Tamer
1. That is the On Star system. 2. Try vinegar mixed 50/50 with water.
DPW_'s Avatar
DPW_
https://www.corvetteforum.com/forums...indshield.html
Old Sep 8, 2017 | 08:00 AM
Northshore3lt
Thanks!
Unfortunately the vinegar solution did not work on the mirror, any other suggestions?
Old Sep 8, 2017 | 08:03 AM
Corvette_Ed's Avatar
Corvette_Ed
Originally Posted by Northshore3lt
Thanks!
Try rubbing alcohol.
Old Sep 8, 2017 | 09:46 AM
deriley's Avatar
deriley
Veteran: National Guard
Default 2 quick questions
to remove the film on your rear view mirror or any glass use 00 steel wool and elbow grease, make sure the steel wool is 00. you can get it at Walmart
Dan
Old Sep 8, 2017 | 09:47 AM
DJSpeece's Avatar
DJSpeece
I have some sort of dried solvent on my BMW's windshield which i bought used. When the sun hits at the right angle it appears as though someone dripped some liquid at the top of the windshield and let it run down unevenly. I have tried isopropyl alcohol, acetone, paint thinner and the usual commercial window cleaning products to little avail. I am thinking about using fine steel wool in some inconspicuous place on the windshield (if there is such a place) to see if that might work and at least not make the situation worse.
Old Sep 8, 2017 | 10:14 AM
deriley's Avatar
deriley
00 steel wool will work fine on mirrors and glass, no scratching. Just be sure it is 00. Also works equally well on chrome, do not use on paint or plastic as it will scratch. Try it, you'll like it.
Dan
Old Sep 8, 2017 | 06:17 PM
Florida Sport's Avatar
Florida Sport
The best glass cleaner I have found is the "ultimate Cloth" from Southern Car Parts. It uses no chemicals just water.
Old Sep 8, 2017 | 06:24 PM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Dan
Dan
Do NOT, I repeat, do NOT use 00 steel wool on your windows or glass. 0000 might be okay but I am not a fan. Try a Mr. Clean magic eraser on the overspray on your rear view mirror.
Old Sep 8, 2017 | 07:27 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
Dan
If you use steel wool at all, it should be 0000. That's the finest grade. Even that might scratch the glass if you get too aggressive.
Old Sep 8, 2017 | 08:29 PM
cmonkey713's Avatar
cmonkey713
As others have said, don't use #00 steel wool! If using steel wool only use #0000 which is very fine and will not scratch the glass.
To Two Quick Questions
