The lights are in 2 pairs, One pair for the left side and one for the right side.
The back of the C6 is slightly curved. Each pair is slightly angled so that the lights will be straight back after you install them.
If you look at the OEM ones that you took out you should be able to see the difference in the light housing.
If you are standing centered behind the car about 20 feet back and the lights are on, all 4 lights should look the same, with the same clarity and brightness.
If they don't you have some installed on the wrong side.
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
This is correct.
LH sides on the drivers side, RH sides on the passengers side. Inner and outer doesn't matter.
Looks great. I have the same tinted Eagle Eyes from JWM. Couldn't be happier. Always get compliments on them. Definitely the best tails for the C6 IMO.
