Vinyl Wrap
A. Buy knifeless tape
B. Watch A LOT of youtube videos
C. Buy a full roll, and wrap some small things
D. Wrap in small sections, do NOT try to do the entire side of the car like you see wrap shops doing. Measure the size of the door, cut a piece just oversize, wrap that, etc.
E. Understanding the behavior of the material is the hardest to learn, and absolutely 100% CANNOT be learned, or understood in your first vehicle.
F. Amateurs overstretch and over yield material. It may stick and look finished at first, but the failures will come, and quickly. Longevity of the wrap will suffer, as well as the color saturation of the material.
G. Have a large work surface available to unroll and cut the material.
My suggestion is, if you're going to wrap your own car from scratch with zero experience, you're in a for a ride. I'd get at least 2 rolls and plan on redoing the car in the short time frame.
The way I learned was much the same. I bought 3 rolls, wrapped a roof, then a hood, then some small pieces, then a car (was not great outcome but decent), then another car (was better), then had some 3m guys at SEMA give me a couple hour crash course, then wrapped another car. By the fourth car, I was clean, mistake free, under the weather stripping, totally 100% customer service ready. At that point, it's about getting faster.
I've done some and it aint easy
NSF
I few additional comments and my 2 cents FWIW. I wrapped my halo (2 times ) and console ( 3 times ) before I was happy with it.The knifeless tape will leave a (barely if you do it right) visible edge, on use it on the edges of the panel not on flat areas.
I also recommend:
- Do not you not touch the back side that is going to touch the panel.
- Use a little heat to relax the wrap after you have it the way you want it.
- Use heat when you stretch and don't stretch if you can.
- Clean the surface, then clean it again before wrapping
- (Some people say this doesn't help) Use a primer where the wrap edges are going to be.
I used up quite a bit of wrap before I went from worthless to amateur status. Did not take a class, watched a lot of YouTube and sent a lot of wrap, compared to what I finally used, to the trash. As K.I.T.T recommended, if I was going to wrap $$$ an entire car I would take a class. On the other hand if you can handle a lot of frustration and have attention to detail you can do it with a helper after some practice.
