Clicking from drive train when accelerating and decelerating
Old Sep 28, 2017 | 09:08 AM
Peter Kelly's Avatar
Peter Kelly
Default Clicking from drive train when accelerating and decelerating
When driving my 2012 GS with 60K on the odo I am hearing a single click when I step into the gas and a double click when I let off. Sound is coming from the trans area.
No other issues, not affecting driveability or anything else that I can tell, just an annoying clicking sound that has never been there before.
Old Sep 28, 2017 | 09:34 AM
electricfish's Avatar
electricfish
Sounds like loose axle nuts, there is a tsb on this, I followed it and it fixed the clicking in my 06. I don't have the directions handy but search for axle nut tsb on this site.
Old Sep 28, 2017 | 10:02 AM
Suns_PSD's Avatar
Suns_PSD
Worn engine mounts.
Old Sep 28, 2017 | 10:16 AM
Cuckoo's Avatar
Cuckoo
My 2011 GS with only 12700 miles has the same sound since I bought it last year. It sounds like it comes from the the front, sometimes the center, but its hard to tell.
I'm just figuring its a vette sound. It seems like they all have their own personality of sounds.
Old Sep 28, 2017 | 10:20 AM
Corvette_Ed's Avatar
Corvette_Ed
Originally Posted by Suns_PSD
Worn engine mounts.
This is kind of doubtful. As mentioned, axle nuts, or possibly end links.
Old Sep 28, 2017 | 04:14 PM
Peter Kelly
Ah well, I'm selling it soon so Ill just let that go.
Wonder if the items mentioned are covered by GMPP?
Old Sep 28, 2017 | 07:25 PM
BlindSpot's Avatar
BlindSpot
A little bit more info - M or A?
Sound coming from straight start/stop? Or when turning?
Motor mounts are not the issue, axle nuts not probably if the start/stop is on a straight line.
How about the sound. Does it sound metalic? Electronic?
Old Sep 29, 2017 | 10:29 AM
Peter Kelly
Its a manual, it definitely sounds metallic. Its when accelerating from either a stop or while moving. Its not when the wheel is turned that I am aware of.
Old Sep 29, 2017 | 12:16 PM
BlindSpot's Avatar
BlindSpot
These are definitely not the symptoms of loose axle nuts and definitely not motor mounts. It cannot hurt trying the axle nuts for tightness as it is so easy to do, but if they're loose it is coincidental to this sound.
If you're getting a rhythmic metallic click while moving (you didn't mention "while moving" in the first post), starting, stopping, then need to start looking at bearings somewhere. These could be wheel bearings, torque tube bearings, etc. Numerous places including internal bearings in the trans or differential. I couldn't begin to narrow anything without hearing it in person.
Old Sep 29, 2017 | 01:22 PM
235265283...'s Avatar
235265283...
Peter:
There is another thread on exactly this same subject (which I just now bumped up): "C6 Clicking Noise".
Note in particular Post #8 on that thread which summarizes what my dealer said.
Please be sure to post if you succeed in getting a definitive diagnosis.
BTW, your + my posts provide a clue: Click is there for both manual and AT.
Old Jan 12, 2018 | 01:43 PM
Peter Kelly
Dealer says it is "slop" in the drivetrain. Ridiculous.
The car is being sold soon so Im not going any further down the rabbit hole on this one. Thanks guys!
Old Jan 12, 2018 | 02:25 PM
windyC6's Avatar
windyC6
I've had many bearings go bad in many areas and have never had one make a clicking sound. Usually a hum or that awful crunching and grinding sound.
To Clicking from drive train when accelerating and decelerating
