Bolt coating? Aluminized? or?
Old Sep 29, 2017 | 04:17 PM
ShiftLess's Avatar
ShiftLess
Default Bolt coating? Aluminized? or?
Most of the hardware on the Corvettes is coated in aluminum (I think).
Is there a source for replacement parts? other than the dealer?
I think the hardware is aluminized. Is that correct?
Yes I just snapped something...
also...why do the parts diagrams ie Cultrag/GM Parts suck so bad? I've never seen such incomplete parts diagrams (the Germans call out every nut, bilt and screw)...makes thing much easier.
Old Sep 29, 2017 | 07:46 PM
mikeCsix's Avatar
mikeCsix
Those are the diagrams provided by GM. Gene doesn't have anything to do with it.
I wondered about the coated fasteners myself, couldn't find any information on them. Corrosion may be the big issue, but haven't heard or seen much info on that either. Some of the guys use ARP fasteners.
Old Sep 29, 2017 | 07:59 PM
96GS#007's Avatar
96GS#007
There are a variety of coatings. Many are zinc coated, but there are coatings that are a mix of zinc and aluminum as well.
McMaster-Carr, Fastenal and Eastwood are all good sources and are often cheaper than the dealer.
Old Sep 29, 2017 | 09:33 PM
rkj427's Avatar
rkj427
Pro Mechanic
The GM Fastener size and torque values are in GM Service Manuals, not typically in the Parts Catalogs unless they are specific bolts such as those used in engine assemblies.
if the bolt is small and not a large threaded undercarriage bolt, your local hardware store may be a source as well.......
Old Sep 30, 2017 | 02:04 AM
grady's Avatar
grady
Look up ARP. I just purchased throttle body, alternator, valve cover and coil pack bolts in polished stainless.
To Bolt coating? Aluminized? or?
