Adding NPP Option
I've seen NPP mufflers go for as little as $300. Seems to me like this would be a much more economical solution.
I was wondering if the hardware for NPP is available in kit form and be installed on an existing car.
If so, is it a bolt on? How much wiring or vacuum line installation is required?
Thanks for any help in advance.
) I took it to a muffler shop and they cut off my base mufflers and welded in the Z06 ones and re-installed for $100. The first NPP in a box was the early design that incorporated a vacuum pump. I installed it in about 20 minutes. Sometime later it failed and the company sent me their newer style replacement (no charge), which took over an hour to install, mostly because of the route I took for the tubing.
Current list price for just the mufflers (includes the axle pipe) is $2240 plus tax. About $1500 from an online dealer plus shipping. NPP in a box not included. So yeah, I could see someone charging $2K installed, but only if it was brand new stuff.
So I guess the "miss" here is that that I assumed ...
We also don't want to mislead those that might have the skills to do it in the garage with some beer and a friend like I did ....
Dave
when people start with comments like..... "He's a rip off! I could done that myself for FREE....."
That has no bearing on what a registered insured shop charges....
Fact is, you can pay top dollar for parts or you can get them for free....
And just because someone has a lift in their garage at home and does their own work, does not mean I'm a rip off or whatever....
Everyone here (including myself
) has made comments on this forum that, while not intended to be derogatory....Could have accidentally stepped on someone else's toes here or there by what you post.
Again, as a paid vendor, shop owner, liability insurance policy holder, bla bla bla.... I don't like seeing
posts that imply that my pricing is out of line...
I appreciate your feedback.
Chuck CoW
So I just can't add the valves onto my existing non-NPP mufflers? I need to get an additional set of mufflers that are made for the NPP option?
If I find a set used, shouldn't the valves already be attached to the mufflers> Or, am I not understanding the configuration?
An yes the valve will be inside the tailpipe and you will see the actuator above the tail pipe. One valve and actuator per tailpipe. If you have any questions you can PM and I'll try to point you in the right direction.
There were two different angles on the 2 1/2 NPPS and then you have the 3 inch BI Mode ZO6 type
Save yourself a lot of trouble and try and purchase a set that fits your car using the parameters above. you can make any set fit but save yourself a lot of trouble and buy the correct mufflers and they will bolt right up
Dave
Chuck CoW
