Adding NPP Option
Old Oct 6, 2017 | 02:16 PM
Jaydubgt's Avatar
Jaydubgt
Default Adding NPP Option
I'm looking to buy a 2013 C6 Grand Sport. One of my "must haves" while looking for the car is the NPP Exhaust Option. The car I'm looking at has all of my other "must haves" but this one.
I was wondering if the hardware for NPP is available in kit form and be installed on an existing car.
If so, is it a bolt on? How much wiring or vacuum line installation is required?
Thanks for any help in advance.
Old Oct 6, 2017 | 02:23 PM
Chiselchst's Avatar
Chiselchst
I would not let the lack of the NPP option stop you. I had the same choice, I bought the car. Glad I did...
Much discussion here about NPP, often can be had here used...
Not too difficult - just vacuum hose to activate actuators (and electrical valve to open/close).
Serch is your friend
https://www.corvetteforum.com/forums...rchid=66763087
Old Oct 6, 2017 | 02:25 PM
Matthewstorm's Avatar
Matthewstorm
I spoke to Chuck Cow about doing this (super nice guy BTW) and it can for sure be done but I think it's close to 2K maybe more.
Old Oct 6, 2017 | 02:33 PM
d.medic's Avatar
d.medic
St. Jude Donor '10
You can usually find the exhaust used on here for <400. Then I believe all you have to do is add NPP in box. You could always go with an aftermarket NPP system, I believe those can be had for <1500.
Old Oct 6, 2017 | 08:22 PM
jaybee924's Avatar
jaybee924
NPP in a box is right at about $200 but the NPP mufflers go from $400 to maybe $600 but just makes sure you get the right size for your car. If you have a Z06 make sure you get the Z06 mufflers. If you have a base/GS make sure you get the base/GS mufflers. Make sure you get the right years also. Base 05-08 same routing mid-pipe, Base/GS 09-13 same routing mid-pipe both those years is 2.5" at the connection from mid-pipe to muffler. The Z06/ZR1 is 3" at the connections from mid-pipe to muffler.
Old Oct 6, 2017 | 09:08 PM
Dcasole's Avatar
Dcasole
Two K ...... what are u smoking lol lol
bought my mufflers for 500.00 and my NPP in a box for 180.00 , 50 bucks at a local muffler shop to hang the mufflers and i installed the NPP
best of both worlds , loud when you want and quiet when it has to be
Dave
Old Oct 7, 2017 | 12:17 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default NPPz............
Dave
NPPz............ Start to finish, mufflers, shipping, NPP controller, installed..... (by a real registered shop that
charges labor and carries insurance ) will often be somewhere in the "teens" for a complete job start to finish.
Price always depends on what condition the mufflers are in and where they come from.
Not all years fit all cars.... The mufflers you get on e-bay..... May (or may not) match your x-pipe even if they are 2.5 inches
just because your originals are 2.5. With most installations we do, we also provide an x-pipe that matches, as it does not much of the time.
Many people bring us 3" ZO6 mufflers.... But they don't fit the automatic cars and even if it's a stick....they won't
match your x-pipe. Often, we provide a FULL 3" C6 ZO6 exhaust from the manifolds to the muffler tips....with a controller.....
Please people, before you trash someone's business, price, or products..... Please know EXACTLY what you are talking about.
Most time we explain that a "from scratch" NPP install is usually about the price of a new BORLA STINGER install... Only
you can turn the sound on and off with NPPs.
Chuck CoW
Old Oct 7, 2017 | 07:17 AM
tprice's Avatar
tprice
I completely agree with you NOT considering ANY Vette without NPP
I have it on mine and would NEVER even look at another Vette without it, yes it can be added but gonna cost you a lot more money
Old Oct 7, 2017 | 08:10 AM
Dcasole's Avatar
Dcasole
Chuck CoW
Chuck, the post was never meant to trash your business ...I am probably one of the few people that stick up for you ,all the time , there is a right way and a wrong way to correct my assumptions and once again you took the wrong way as always ......you would think as a business professional you would have learned that by now.....
it was assumed that the guy is buying a car without NPP and he wanted to add just NPP ....
one would assume again that the OP or you in this case would buy the correct set of mufflers that do not need a new X PIpe or bending to go around the transmisson.........
So with all that said, Yes $2,0000 is a crazy amount of money to spend to purchase and hang a set of axle back mufflers and add a NPP in a box .......
Dave
Old Oct 7, 2017 | 09:17 AM
BadAV's Avatar
BadAV
I gave $400 for my NPP mufflers and a little over $200 including shipping for my NPP In a Box. I did have to drive from St. Louis to Indianapolis to pick the mufflers up so it cost me about $50 in gas and a day of driving. If you are even a little mechanically inclined it is pretty easy to remove the mufflers and install the NPPs. It took me between 2 and 3 hours to install the NPP In a Box; I took my time. I did get the adapter that allows you to tee off the MAP sensor rather than fight trying to tap into the vacuum port on the back of the intake.
Old Oct 7, 2017 | 10:25 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
Default Assuming.....
Dave
Dave.... Assuming you get the RIGHT MUFFLERS, AT THE RIGHT PRICE, INSTALL YOURSELF, and PAY NO SHIPPING.....
AND have no complications.... Sure, you can score an NPP job under a grand....... Most people should be sooo lucky.
While you might not have intended to trash my business, but your comment.....
Dave
.... directed at a customer I quoted in this thread....You can see how I might be put out as you're implying I'm way out of line.....
Yes, at HOME DO-IT-YOUR-SELF NPP installs can be under $1,000. I've seen a few.
If you're going to "tell the shop you want NPPs." and let them locate them, be sure they fit the car....provide an x-pipe that matches,
(good clean NPPs of the right year and size are often tricky to find and 3" don't fit most cars (with more mods), install them, install the
conversion box.....etc... All the while, like any REAL shop..... Provide the labor and misc parts.....
Don't expect the final cost to be same as you would pay if you did it at home with your buddy and a case of beer.
I think it's fair to say that....
No offense taken.
Chuck CoW
Old Oct 7, 2017 | 11:29 AM
Dcasole's Avatar
Dcasole
No offense taken.
Chuck CoW
Awesome ... as I did not mean to offend you in any way !
So I guess the "miss" here is that that I assumed ... and the person that made the statement did not state that you were supplying everything
We also don't want to mislead those that might have the skills to do it in the garage with some beer and a friend like I did ....
Dave
Old Oct 7, 2017 | 11:36 AM
Dcasole's Avatar
Dcasole
I did the same thing except I did fight that little " TAP on the back "
If I realized how easy it was to just remove the manifold I would have skipped using all those nasty words which resulted in some really bad looks from my wife and getting the nasty cuts on my hands
Dave
Old Oct 7, 2017 | 11:39 AM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
I sold my NPP mufflers off of my 2011 GS with 12,000 miles to a local guy for $350.
He installed them himself on his Base C6 and then paid somewhere around $200 for a 'NPP in a Box'.
So, I guess his total price was aound $550
BTW ... The NPP was a $1,195 option on my GS.
Old Oct 7, 2017 | 11:45 AM
Turbo6TA's Avatar
Turbo6TA
Originally Posted by jaybee924
... just makes sure you get the right size for your car:
Make sure you get the right years also ...
05-08 same routing
09-13 same routing
Good points !
Old Oct 7, 2017 | 11:49 AM
Dcasole's Avatar
Dcasole
yep that's what I paid to install ... but i had to pay shipping on the mufflers and I did not feel like wrestling the pipes in place when the muffler shop only charged me 50 to hang ...
best mod i have done on the car .....
Dave
Old Oct 7, 2017 | 01:50 PM
Turbo6TA's Avatar
Turbo6TA
I really liked the NPP on my GS ... but
After I installed a set of catted headers, the car was so damned loud when the NPP valves opened up at wide open throttle that I finally replaced the NPP with a set of Borla 'Touring' mufflers ... noise problem solved
The NPP was just fine with the headers during normal driving, but again, it was obnoxiously load at full throttle (valves open).
To Adding NPP Option
Old Oct 7, 2017 | 03:18 PM
Dcasole's Avatar
Dcasole
Is that not the reason for installing NPP in the first place ....
I love the sound with the headers and the gates open ....but when I am tired of it ... I just close them ...
Dave
Old Oct 7, 2017 | 10:30 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I am one who add NPP to his 09, was not a big deal, I added the ZR1 exhaust front to back so go for it.
Old Oct 7, 2017 | 10:49 PM
jaybee924's Avatar
jaybee924
No your not. When I got my GS it had the stock exhuast on it. I was looking for a C6 with the NPP. So I didn't look long enough to see what would be required to make that happen if it could so I bought a Corsa extreme exhaust which was great. I knew I was going to go with headers and cam. So it is a great option. I picked up a set of NPP mufflers with muffler mod off here and installed the NPP in a box and never looked back. Sounds good just ready to get the headers (whenever they come in, ordered KooKs from a vendor got the headers but not the catted X-Pipe and Halltech) and cam installed.
