Did My Own Halos And Spoiler - Pics
I did my own halo job on my headlights. I painted the bezel satin black, painted the chrome rings around the headlights to match the car, and cut down the blinker bulb to make a matching ring to mount the switchback halos. I used 60 mm, 70 mm and 90 mm halos from diode dynamics.
Lfzebra (10-15-2017)
Looks great
I'd like to see more during pics & maybe a quick note on how you went about the project on the halos
That is awesome nice.....
Only unexpected problem I hit was that I didn't realize the DRL runs on the same wire as the turn signal, so the DRL wants to shine orange all the time. The pics above are with park lights on. I have ordered a kit from RadioFlyer that separates the DRL and turn signal wires so you can have white DRL's and flash amber turn signals. I will have to pull the headlights when I wire that in, so I can take some pics of the headlight removal process then, as well as the three screws that don't back out I referred to above. I will post them up here when I do.
Use the same baking procedure I described in the headlight post above and pry them apart. There is a clear diffuser ring behind the lens. I sprayed the diffuser ring with VHT Niteshades to darken it. That gives the taillights a dark cherry red look without limiting light output. I then used 3M tape to hold the halos on the top of that diffuser ring. Then use RTV to seal them back up, and tap into the brake and turn signal wires.
I followed this thread for installing the rear halos, with a few exceptions which I go into later in that thread.
https://www.corvetteforum.com/forums...ght-halos.html
One thing I want to point out that is not evident in the pictures. I used the Diode Dynamics halos in the headlight, and Oracle halos in the rear. The Diode Dynamics have a smooth light appearance because of a coating they put on the halo ring. With the Oracle lights, you can see the individual led's. They don't show up in pictures for some reason, so in the pics they appear to be a smooth ring. In person, you can tell its individual led's. They still look great, but you can see the led's. Diode Dynamics do not offer red halo rings in the size needed for the tail lights (150 mm). They said they used to have them, but were having issues with the drivers. I have noticed recently that they now have white halos in that size (and larger) but I haven't seen the red ones listed in that size yet.
Diode Dynamics (10-13-2017)
Former Vendor
One thing I want to point out that is not evident in the pictures. I used the Diode Dynamics halos in the headlight, and Oracle halos in the rear. The Diode Dynamics have a smooth light appearance because of a coating they put on the halo ring. With the Oracle lights, you can see the individual led's. They don't show up in pictures for some reason, so in the pics they appear to be a smooth ring. In person, you can tell its individual led's. They still look great, but you can see the led's. Diode Dynamics do not offer red halo rings in the size needed for the tail lights (140 mm). They said they used to have them, but were having issues with the drivers. I have noticed recently that they now have white halos in that size (and larger) but I haven't seen the red ones listed in that size yet.
Our HD halos are perfect for tail light applications because of the dual-stage brightness options. You can have a running light + brake light setup very easily.
Nick C.
