C6 Fob
Old Oct 14, 2017 | 07:58 PM
vincepicone's Avatar
vincepicone
Default C6 Fob
Sorry if this info is here someplace but I haven't found it. What's the procedure for resetting or re programming my key fobs? Thanks in advance
Old Oct 14, 2017 | 08:15 PM
Vette_DD's Avatar
Vette_DD
Look in the DIY & FAQ sticky:
https://www.corvetteforum.com/forums...9-14-16-a.html
There's a link in there to help you if you're getting a No Fob Detected message:
http://forums.corvetteforum.com/c6-c...hat-to-do.html
Why do you need to reset or reprogram your fob? Some Corvette newbies thought they needed to, but they were wrong.
Old Oct 14, 2017 | 08:26 PM
cclive's Avatar
cclive
If I do say so......
https://www.corvetteforum.com/forums...tructions.html
Old Oct 14, 2017 | 08:57 PM
vincepicone
The car is doing crazy things. You're supposed to get 3 beeps if you leave the fob in the car, but about 1 out of three times I get 3 beeps with the key in my pocket. I replaced the batt. Because it, the fob, didn't work so I thought it needed a reset.
Old Oct 14, 2017 | 09:09 PM
EVRose's Avatar
EVRose
If it allows the car to start it does not need to be reprogrammed.
Old Oct 14, 2017 | 09:29 PM
HK770's Avatar
HK770
Close door and move away from car in a smart manner !!!.....LOL
Old Oct 14, 2017 | 09:41 PM
Vette_DD's Avatar
Vette_DD
You're staying too close to the car after you got out and closed the door. One of the antennas in the car is still detecting it and the car "thinks" you've left the fob in the car. Reprogramming the fob won't fix that. Neither will changing the fob battery, that's why I asked why you thought it needed something done to the fob.
Move away from the car a little faster.
Old Oct 14, 2017 | 09:58 PM
vincepicone
Thanks everyone you guys are great
Old Oct 14, 2017 | 10:03 PM
Bruze's Avatar
Bruze
OP:
FWIW, I always have all keys, and the fob (when I'm driving the Vette) in my left pants pocket and have never had the 3 beep problem.
If you keep yours in your right pocket, try the left -- it will be farther away from the antenna when you get out.
To C6 Fob
