Backup camera problem
Old Oct 15, 2017 | 08:06 PM
Gmurabito's Avatar
Gmurabito
Default Backup camera problem
Installed new Kenwood HU with a pioneer backup camera. Camera works great some times but intermittently when I put it into reverse, the guide lines will appear on the monitor but the rear view camera doesn't show a picture. Any ideas?
Old Oct 15, 2017 | 08:48 PM
Patsgarage's Avatar
Patsgarage
I would start by checking the power lead to the camera. I sounds like the camera is not always getting a "turn on" signal.
Old Oct 15, 2017 | 10:43 PM
Gmurabito's Avatar
Gmurabito
That makes sense. Now that I think about this, I think the guides are a function of the head unit not the camera. So if the're coming on it would lead me to think the problem is with the Camera.
Old Oct 15, 2017 | 10:47 PM
Patsgarage's Avatar
Patsgarage
Exactly what I was thinking. I would start with a multimeter at the camera and work my way up to the HU.
Old Oct 15, 2017 | 11:07 PM
Gmurabito's Avatar
Gmurabito
Thank you.
Old Oct 15, 2017 | 11:09 PM
Patsgarage's Avatar
Patsgarage
Thank you.
Anytime. Nice midyear. Yours ?
Old Oct 15, 2017 | 11:37 PM
Gmurabito's Avatar
Gmurabito
It was. Sold it a while back, now have an 06 base.
Old Oct 16, 2017 | 12:28 PM
Mikey_T's Avatar
Mikey_T
Correct, the head unit is getting the signal from the reverse wire up front but the camera is not turning on. Check the connection to the camera in the back. I had a bad camera when I first installed mine, had to swap it out.
Old Oct 16, 2017 | 03:40 PM
EviLS7's Avatar
EviLS7
What power did you connect your camera to? I spliced into the reverse lights and haven't had an issue. But like some say could be a bad camera as well.
Old Oct 17, 2017 | 12:41 AM
zzjakect's Avatar
zzjakect
Do your backup lights work when you shift into reverse? Could be sensor on tranny. Just a guess.
To Backup camera problem
