C6 Oil Change
Old 11-02-2017, 03:49 PM
Gman in NC
Gman in NC's Avatar
You're right. Oil change, air filters, battery and cabin filter are all very easy on this car. I always do my own at home.
Old 11-12-2017, 07:40 PM
Tammy Simon
2nd Gear
Tammy Simon's Avatar
I just changed my oil on my LS2 2006 Corvette for the first time. I can confirm that the oil plug can easily be reached from outside of the car from the drivers side. I bought a large tin foil pan for 1 dollar and it caught everything after loosening the bolt. It was easy to get the bolt out of the way and not drop it in the pan. The filter is right there behind the bolt and also easy to reach. It was easy to turn with my hand and just place it in the pan. The car sits fairly flat, so maybe the only thing I'd change is to raise up the right (passenger) side of the car by driving on 2x12s to make sure all the oil comes out. Without that though, mine had to be near 100% empty. I'll put mine in stilts another day.
Old 11-13-2017, 09:51 AM
cenzo
cenzo's Avatar
Originally Posted by ward cleaver
i've never jacked up my corvette to change the oil...neither my c4 or my c6...there's no need to.
There's no need to get under the car at all, so your size doesn't matter either.
You can lay on your back and easily reach the drain plug with a wrench. Same thing with the oil filter. All you need is a low profile drain pan for the old oil.
Regards,
-ward
what!!!???
Old 11-13-2017, 10:29 AM
hotinaztoo
hotinaztoo's Avatar
Default Changing oil on the C6
Originally Posted by Kevjud
Do you think the GM engineers really tried to make oil changes so easy in a C6, or is it just a coincidence that the drain plug and filter are so accessible? I wish all of my vehicles were this easy to change oil.
You are kidding, RIGHT??
Old 11-13-2017, 10:39 AM
windyC6
windyC6's Avatar
No...I don't think they are kidding. Think they may have arms that are 8 feet long.....
Old 11-13-2017, 11:29 AM
Not So Fast
Not So Fast's Avatar
Originally Posted by cenzo
what!!!???
Maybe a gorilla arms could do it but not me, wouldn't even try it, I like to wipe things down while I'm under there also, tidy up a bit
nsf
Old 11-13-2017, 01:24 PM
Itshakes
Itshakes's Avatar
Default C6 oil change
Originally Posted by Dave S
Just be sure to allow time for all the oil to drain from the filter....otherwise a real mess!
I usually punch a hole in the bottom of the filter with a center punch, before I remove it. Let the filter drain, and then remove it....way less messy!
Quick Reply: C6 Oil Change
