C6 4LT leather dash issues/repair failure
#41
DAP® WELDWOOD Landau Top & Trim High Heat Resistant Contact Cement
http://www.glueplace.com/dap-weldwoo...rade-1-gallon/
#42
Hi, I have a 2012 GS 4LT and my dash just had this problem. Was your car under warranty when they agreed to replace it? If not, how did the dealer justify this fix? I have a Rick Hendrick dealer near me and I was going to take it there for them to look at and give me some advice on what can/should be done, but didn't know how to approach them. Any suggestions you might have would be appreciated.
Thanks!
Thanks!
MannyS (01-20-2022)
#45
Unfortunately my 2011 Grand Sport has now started to come unglued from up at the very edge of the windshield. Damn it....I guess I should have learned from my 2009 model. Its not bad yet but whats to come is what I hate. What are people doing now to fix this? Ive see pads that will fit over the area but didnt know about that or not.
#46
Edit to add: You could also buy and install a 3LT dash.
sd45t2 (01-13-2022)
#48
dr_gallup (01-18-2022)
#49
If the leather is delaminating near the base of the windshield then there is a cheap and easy fix. This will only work when the leather is lifting near the windshield. Get a length of vacuum hose that reaches from one A piller to the other. Lay the hose loosley at the base of the windshield where it meets the dash. Use your hand or a plastic flat blade tool and push the leather toward the windshield then wedge the hose into the windshield so that it is tight. Continue this along the entire base of the windshield. What you will find when finished is that the hose is barely visible at the base of the windshield as it looks like a gasket. It will keep the leather tight and flat. I did this on my 427 and it works quite well. Unfortunately this is not the solution if the leather is lifting toward the front of the dash or near the glove box. If you don't like it then it is easy to reverse.
#50
Yes, I agree also! But you can remove the entire dash from inside the car. I have done it to install a new HUD. Removing the dash is very simple, technically, all you have to do is just remove all the screws pull the dash out. Since I'm a DIY type, I would just remove the dash and take it somewhere to be reglued. (Actually, I might be tempted to use contact cement on the dash it worked well for me on a '70's Triumph.)
So why doesn't everyone do it this way? Because you need to remove the radio, center console, glove compartment, gauge cluster, etc. It's about 50 screws and 50 clip attachments you need to redo and remember. That's a lot of unnecessary unscrewing and redoing for a shop and time is money. So if you are a DIYer I would do it myself. If you're having it done then they will pull the window to save money in labor cost and time.
#51
Received 8,811 Likes
It’s pulling up by the windshield because it’s cut too short and doesn’t wrap around the edge. I pulled the dash on mine - took just under 2 hours taking my time, sorting and labeling all the bolts, screws, etc. It looks much scarier than it is. I also recommend removing the seats to give you some more room getting under the dash to remove/re-install those screws. Re-install of the dash took just about an hour with my 12-yr old doing most of the install.
http://www.kawal.net/Dash%20Replacement.htm
#52
C7 with leather wrapped dash DEFINATELY has this problem as well !! Pretty much any leather wrapped dash exposed to good old sun/ uv rays will have this problem'
This is NOT a Corvette exclusive.
#53
Celticvette55 (06-13-2022)
#54
I need a little guidance here. Looking at a 2013 4LT convertible with two bigger ripples and one small hump in the dash. Looks like there's two methods. #1 pull WS, reglue and reinstall WS. #2 pull the dash, reglue, reinstall dash. What are the up and down sides of each approach? Typical costs for each of these solutions or some other way to make the dash look good again with a solution that will last?
#55
if you can remove the dash yourself, you’ll save a lot of money.
#58
Mine Is letting go Also
Well, I guess it's my turn. Just this month, my dash started letting go on my 2011 Zo6. After reading and researching, I think I will pull the dash and re-glue it. I've already had the console, nav, and etc out. Shouldn't be that bad. Any last minute suggestions appreciated.
#59
Went to Corvette Adventures in Wisconsin Dells, Wisconsin. It started Thursday morning and ends tonight with a dinner. I parked next to a 2014 C7 Convertible with the 3LT package (leather dash) for a road tour. The current owner told me he bought the car in April of this year with 4,800 miles. The dash behind the steering wheel is already lifting and bubbling. I’ve seen too many C6’s with the 4LT package and now C7’s with the 3LT package with lifting and bubbling leather dashes. Whenever I am searching for a Corvette, I always stay away from any with the leather dashes. It is evident that GM does not know how to secure the leather to base dash material.
#60
I researched removal and re-gluing but decided to go back to the dealer and see what they could do. Went to a local Hendrick dealership (they sponsor our local club) and they agreed to replace the entire dash for just the cost of labor ($1,500) which would have been double otherwise. They did a great job and the new dash is excellent and I'm very happy. Local shops wouldn't guarantee the repair so I didn't want to take the chance. You may want to consider this as an option. Good luck.
