what are the biggest tires that can go with RPI wide body kit with z06 brake upgrade
8th Gear
Well the thread says it all. thinking of swapping out the stock quarters on my 05 magnetic red coupe and trying to figure out the biggest tire with out uosetting alignment and rubbing the quarters, Can i get away with the 12's and upgrade my rear Cray spider rims accordingly. realizing the upgrade is more than just the panels eh!
VinmansC6 (01-07-2018)
i'm running Pirelli 355/30/19 on the back of my z06 mounted on factory spider wheels. They don't rub daily driving, tracking, or autocrossing. Not even really close. I'm running 1 degree negative camber and 1/8 inch total toe in. Ride height is set pretty close to factory.
Are you having any problems with the traction control or active handling systems? And if not what size tires are you running in front? I have a 2013 Grand Sport that I would like to run the 355/30/19's on my stock 12 inch wheels but am concerned that the 355 being .8 inches taller the stock size my cause problems with these systems,I know this is an old thread but I hope you will still reply. Thanks
My fronts are 285/35R-18 Pirelli P Zero SL. No, I do not have issues with traction control or active handling. It's my second z06 with this setup. Probably about 15k miles between the two of them. Has not been an issue. Several long trips from my place in Charleston SC to Daytona and to Atlanta. Daily driven and done a few track days. Not a concern. This is the 2008. My current is a 2009. Don't have any pictures of it handy, but it looks pretty much identical anyway.
front is still narrow body
Thanks for the reply. Your tire combo is 27.4" rear and 26" front. I am going to try the Kumho Ecsta v720 ACR which is 27.5" in the rear and Bridgestone Potenza 71r's in a 275/35/18 in the front. the fronts are 25.6". These will be on extra wheels for auto crossing. You have a differences of 1.4 " But mine will be 1.9". I will mount the rears and try them with my street tires on the front first to see if I need to go to a taller tire in front. I will report back
