Good morning after changing bulbs on turn signal my interior lights stopped working and parking lights also and plate number lights too.Which fuse is burned?changed fuse #8(10amp) didn't help.Car is 2008.Much thanks
Did you try removing the LED bulbs to see if the problem can be resolved? Bill
Sorry for late respond, yes i did change burned led lights to new led and after that this happen. I checked if i installed it correct,everything seems right
There is no connection between exterior and interior lighting except, again, all of the exterior lighting is operated by current supplied through the BCM computer. http://repairguide.autozone.com/znet...3f807df2e8.gif
Hint: this isn't a '53 Buick where switches and battery fuses run all the lighting.
If changing the burned bulbs was all you did, then I suggest you put them back in to see if everything else works as it did before. Is so, the problem is with the replacement bulbs.
did same thing, which fuse # is in charge of inside lights and rear parking lights+plate # light?
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
If you had bothered to look at the schematics I linked you would see that there are 2 fuses and a lot of electronics between. But since your post seems to indicate some lights are working and some aren't, that would eliminate fuses that run both lights that are working and those that aren't. If you aren't able to decipher a schematic I suggest you take it to a shop.
