Who's going to change to the Mobil 1, 0W-40
#82
this is so inaccurate it’s comical. Idle pressure on the non dry sump engines is rarely over or at 30 psi when oil is over around 200 deg for most LS engines....and that is normal. The high weight is the same as what is spec so the high temp viscosity is the same as spec. The low weight mumber means better viscosity flow when colder than 5 weight. You want the oil moving around with ease when cold. 0-30w is actually a better oil for northern cars in the cold months.
#83
#84
On Demon340's quote, I could quibble and say that it pumps just as fast since oil pumps are positive displacement, but once it gets there, it's too thick. So for practical purposes, our points are the same.
dmk0210 (03-01-2018)
#85
Assuming the VI improver is stable (a nontrivial assumption) 0W is better than 5W for all drivers, including ultra hot places like Las Vegas in the summer. All oil is too thick at startup. ... The only downside of 0W is that it requires more VI improver to make, and VI improvers have historically had shear stability issues....
Or at least a shorter oil life if you are using it under "severe driving conditions" (to quote the manufacturer term)?
#86
I know that conclusion was correct when I retired in 2010. It is possible that VI improvers are better (ie, more shear stable) now than they were then, but I’d be surprised if they were as stable as good quality base oil.
The following 2 users liked this post by LDB:
dmk0210 (03-01-2018),
FortMorganAl (03-02-2018)
#87
Thanks. It seems like a worthwhile tradeoff for my use.
#90
Cruise-In II Veteran
Cruise-In III Veteran
This oil is meant for the C-7 and mostly if the car is driven very hard. The C-6's will last for many, many miles if you use the recommended oil. It doesn't have to be a specific brand. Now why don't you tell me what is the best kind of anti freeze to use? Just kidding.
