Auto trans w/paddle shift
I have a c6 with the auto trans and paddle shift. I have 51000 miles and wondering if i should have the tranny fluid changed? I have a delay in shifting between 1st & 2nd. Anyone else experience this?
Appreciate the input. Thank you
(h) Change automatic transmission fluid and filter if the
vehicle is mainly driven under one or more of these
conditions:
− In heavy city traffic where the outside temperature
regularly reaches 90°F (32°C) or higher.
− In hilly or mountainous terrain.
− Uses such as high performance operation.
otherwise, every 100,000 miles.
See page 6-6 and 6-7.
As far as timing, the transmission is computer controlled. The software is designed to protect the transmission, keep you out of the weeds, and maintain a consistent shift quality throughout the life of the transmission. To keep you out of the weeds the transmission will often up-shift softer or even not at all. If your tires are on the verge of breaking loose the last thing you want is a sudden large increase in torque from shifting to a higher gear.
If you do change the fluid NEVER get a flush. You have to change the filter to do it right or you are just stirring up the gunk. But don't expect any change in performance. The only reason to change fluids is to restore additives that were destroyed by heat. If there is any change at all the computer will quickly restore the same factory shift timing the factory designed. From the shop manual:
This spring I have an opportunity to swap out my original A6 with a later model that's just been rebuilt to good as new. Some might consider this overkill, In fact it will be part of a bumper to bumper update that includes a wideband retune of the Edelbrock E-Force supercharger, an optimal retune of the A6 to remove the most offensive nannies, and replace/pin a failing harmonic balancer.
Now for my "expert" opinion (LOL) gained from experience and not reading. If you decide to change your fluid every 30-K then you might as well do the whole thing, flush and all. At that mileage there is not really any build up of gunk to worry about. But if one waits till 60 - 80-K to do the first change then i'd skip it all together unless theres a tranny problem which could/would possibly become worse after even just a change and not a flush also. Usually...and unfortunately, if someone runs into tranny problems with higher mileage, the tranny isn't long for the world anyway, the change or flush will just speed up the implosion.....
