Quick Jack!
Old Apr 6, 2018 | 06:04 PM
BLUEMEANIE's Avatar
BLUEMEANIE
Originally Posted by duk007
I did my full exhaust on mine. Kooks headers all the way back to the B&B mufflers . C6Z
thanks!
Old Apr 6, 2018 | 09:45 PM
pagosawingnut's Avatar
pagosawingnut
Veteran: Marine Corps
St. Jude Donor '17
Originally Posted by 2012CyberGrayGS
Is it the extended length or regular length?
I ask because I need the extended length for my Lexus but the extended length jack minimum jack points seem almost too far apart. The 37.4" lands about right in the middle of my pucks. Are C7 jack points the same distance? I may upgrade to a C7Z soon.
I don't have an answer for that right now. I do know that there is another tray to put the lifting pucks into and I have to skinny it down to the middle position on the front lifting tray so I bet there would be plenty of room.
Old Apr 7, 2018 | 01:09 PM
2012CyberGrayGS's Avatar
2012CyberGrayGS
Thank you!
Old Apr 7, 2018 | 11:44 PM
2012CyberGrayGS
I just saw your PM. Will respond tomorrow. Too late tonight.
Old May 9, 2018 | 03:16 PM
2012CyberGrayGS
I ordered the BL-5000EXT and I could make it work. I ended up returning it because FedEx lost the box with the power unit, hoses and fittings. I saw they went missing right from the beginning after my shipment arrive and i was missing a box. That was 1 week already. After notifying QuickJack and requesting for them to send what went missing they never responded after several days of calling and requests. What a disappointment. The return was a nightmare to until i talked to the right person. I really needed it. Back to the ramps and messing around.
Old May 10, 2018 | 10:38 AM
reasonable suspicion's Avatar
at the price structure these are, why not just get a 4 post lift instead? Seems overpriced imo.
Old May 10, 2018 | 11:16 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
True, but I have a beam in my garage and the ceiling is quite low, split level home. The QJ fits some garages better, like mine.
Old May 10, 2018 | 02:40 PM
danzio56's Avatar
danzio56
Personally, if having room wasn't an issue I think a 4-post would be a much better choice. Fact is you can store this Quickjack in an extremely small space, up and out of the way. A 4-post not so much.
Old May 10, 2018 | 02:51 PM
windyC6's Avatar
windyC6
While I can see the advantages to a 4 post lift, seems like one big dis-advantage would be that you can't do any wheel off work without jacking up the car while it's on the lift. In other words you still have to jack the car up if you want to remove a wheel .....what am i missing ??
Old May 11, 2018 | 09:26 AM
If you have the height in your garage there is no disadvantage. Drive on the lift, then lift it, then walk under it and use the sliding jack to jack the suspension. No laying on the ground, ever.
Old May 11, 2018 | 09:28 AM
Also easy to just lift the lift without a car on it to get it out of the way. The post footprints are only a foot square.
