Oil Changes
Old Apr 11, 2018 | 05:05 PM
LDB's Avatar
LDB
Originally Posted by HOXXOH
Everything you mentioned as causes/reasons why oil needs changed are part of the data input to the OLM algorithm. It's a far better scientific approach than miles or months ever were.
Yup, but at least back in C6 days (not sure about C7) it was hard coded not to exceed a year. My point was that if mileage is low due to the seldom driven rather than short trips reason, you don’t have to change at a year just because of the OLM’s hard stop at a year. The prior statement assumes out of warranty because going past OLM could potentially give warranty issues if GM found out.
Old Apr 11, 2018 | 05:42 PM
windyC6's Avatar
windyC6
Originally Posted by Racer1735
If you use a quality synthetic oil, you can run some ridiculous mileage intervals (assuming a normal driving style, no track days). However, the limiting factor is the oil filter. All things considered, I change oil in my cars and bikes at 6000 mike intervals. The oil could go much longer but I want a fresh filter.
Then why not just change the filter ??.......
Old Apr 12, 2018 | 10:57 AM
z28lt1's Avatar
z28lt1
I think you have that backwards. The c6 does not 0 out at a year, so you can go beyond the year and still see what the OLM thinks about the oil. Note, GM does not recommend going past a year regardless of the OLM. In the C7, the OLM will 0 out in a year even if not driven.
