09 base extended studs question
Hey guys, just purchased a 09 Black Corvette and i absolutely love it. It has the stock black zr1 wheels on it and i wanted to put some 12mm spacers on it and i know i will have to run longer studs on it, will a 55mm (2.20 inches) stud be good enough from your guy's experience? I found some online that are a good price so i was about to purchase them. Please let me know, thanks a lot guys
This may help. From Doug Ritchie Motorsports.
You may be able to use stock length studs that are threaded to the tip. If you ever want to eliminate the spacers/return to OEM, you won't have to change the studs again.
DRM is an excellent source for spacers/studs/etc.
