dashboard warning light c6
Old Apr 27, 2018 | 12:18 PM
Gera96ss's Avatar
Gera96ss
Default dashboard warning light c6
I got some warning sings last night on my car it was the service fuel system,abs,turn off the car n started back up and they went away I was reading some threads of people having the same issue supposedly check the fuses under the passenger side can anyone relate?
Old Apr 27, 2018 | 02:09 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Quite often those are a sign of a low battery. It could be the battery or the charging system.
I suspect you are not experienced working on cars. I would take it to a Corvette specialty shop if one is nearby.
Also, post up what year car, how long have you had it, what has been done to it...
Old Apr 27, 2018 | 04:12 PM
Gera96ss's Avatar
Gera96ss
yes I am not experience with these cars I’ll try replacing the battery thank you 👍🏼
Old Apr 27, 2018 | 04:22 PM
Welker1's Avatar
Welker1
Before replacing it, have it load tested at your local parts store to see if it's bad. AutoZone and most other parts stores will test it for free.
Old Apr 27, 2018 | 05:57 PM
Gera96ss's Avatar
Gera96ss
Sure will thanks 👍🏼
Old Apr 28, 2018 | 12:41 AM
Cherokee Nation's Avatar
Cherokee Nation
If it went away you are good to go unless it comes back on..Computer glitches.
Old Apr 28, 2018 | 01:35 AM
owc6's Avatar
owc6
In my experience, load testing tells nothing.
Every bad battery I've had has "load tested" just fine. Every single one.
Replaced the battery, and the "symptoms" went away. And I've replaced a few C6 batteries.
Old Apr 28, 2018 | 11:24 PM
Cherokee Nation
What year vette and how old is the battery? You would not get those warning with you car running if you have a bad battery.If your alternator is working and putting out 14 plus volts.
Old Apr 29, 2018 | 11:07 PM
Gera96ss's Avatar
Gera96ss
it’s a 2005 I had a friend test it said the battery was good we started the engine n the alternator bolts went down to 9 can that be the problem?
Old Apr 29, 2018 | 11:10 PM
SladeX's Avatar
SladeX
Was it just a blip of 9V or did it stay at 9V after the car was started and it was idling?
The alternator should be outputting 14+V at idle with nothing but the engine on (no lights, fans etc)
Old Apr 30, 2018 | 12:22 AM
Cherokee Nation
Yes...."Houston We Have A Problem".
Old Apr 30, 2018 | 01:38 AM
Gera96ss's Avatar
Gera96ss
also one of my lights is brighter than the other one can that b the problem as well not having too much power?
Old Apr 30, 2018 | 01:42 AM
Gera96ss's Avatar
Gera96ss
It was just a blip then the battery gauge was lower then 13 we Accelerated n went over 13 also the interior light flicker I was told that those alternators have some type of clutch in them that messed up really quick
To dashboard warning light c6
