Dropped a Socket
Old May 11, 2018 | 09:58 PM
KyJim's Avatar
KyJim
Default Dropped a Socket
Replaced my battery tonight and after tightening the hold down bolt the socket pulled off the extension when I pulled it out. Sounded like it fell down into the fender liner.
Anyone had this happen and how hard is going to be to retrieve this socket ?
Old May 11, 2018 | 10:16 PM
87SAM's Avatar
87SAM
You can take the fender well liner off, or just forget about it.
Old May 12, 2018 | 12:37 AM
Cherokee Nation's Avatar
Cherokee Nation
It will fall out someday,somewhere.
Old May 12, 2018 | 01:51 AM
Jaime-Corvette's Avatar
Jaime-Corvette
I found a free wrench in my c6 when i changed its battery
Old May 12, 2018 | 03:28 AM
Elijah71's Avatar
Elijah71
Go pick up a small telescopic magnet https://m.harborfreight.com/15-lb-ca...ool-95933.html
Old May 12, 2018 | 07:32 AM
BadAV's Avatar
BadAV
Just forget about it. Is it really worth ripping some of the car apart to maybe get it back? I did the same thing once, except it was on top of an intake manifold and the socket dropped into a black abyss. I couldn't physically find or see the socket so I just gave up and forgot about it.
Old May 12, 2018 | 08:27 AM
cart7381's Avatar
cart7381
Forget about it or fish around with a magnet
Old May 12, 2018 | 08:51 AM
KyJim's Avatar
KyJim
thanks guys.....guess I'll take everyone's advise and forget about it unless I can here it rolling around and driving me crazy.
I will pick up one of the telescoping magnets and try that, otherwise I will need to pick up another set of sockets as my 10mm is in the abyss.
Old May 12, 2018 | 08:55 AM
gilhuly's Avatar
gilhuly
no worries, you can buy individual sockets
Old May 12, 2018 | 09:19 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
I set one down the other day when I had the trunk on our vert open. Mr. Bumbles hit it and it went down the drain hole. Laid underneath and tapped and tapped. Along with dirt, rocks and leaves out popped a socket!
Old May 12, 2018 | 10:01 AM
Racer86's Avatar
Racer86
Hope it doesn’t fall out and put a hole in your rear tire.
Old May 12, 2018 | 04:31 PM
JABCAT's Avatar
JABCAT
The liner is simple to remove, I’d pop it off & get the socket out.
Old May 12, 2018 | 08:18 PM
reasonable suspicion's Avatar
get the socket out.... if you can't find a socket, never change your hid bulbs those retainer screws are hard to find
Old May 12, 2018 | 10:30 PM
seijack's Avatar
seijack
Yes I have, TWICE.....take the lower rear fenderwell screw out and tap the inner fenderwell liner...this will dislodge the socket and it will come rolling out..at least it did both times I used this method, then be sure to re-install the lower fender liner screw. Good Luck!
Old May 12, 2018 | 10:55 PM
owc6's Avatar
owc6
Best answer!
Old May 13, 2018 | 06:20 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Must be the "10mm blues", Jim. I lost a 10mm socket in another car changing a battery, too. I looked around, hoped for it to fall out on the garage floor, etc. Never did. Sold the car with "it" still in there---somewhere. Oh well. And to all the rest: thanks for reminding me that I need to get another 10mm socket. I've been using wrenches and a visegrip on occasion---not good substitutes!
Old May 13, 2018 | 08:06 PM
KyJim's Avatar
KyJim
Yep Bill, time to go get another socket. I'm going to take out the lower screws and se if it comes out. Drove it for the first time this year yesterday and no noise from a socket rolling around.
To Dropped a Socket
Old May 13, 2018 | 11:01 PM
cb1980's Avatar
cb1980
Old May 14, 2018 | 07:14 AM
Katie22's Avatar
Katie22
Had this happen. I simply removed the battery holder itself and then was able to reach down and get the dropped socket.
Old May 14, 2018 | 07:42 AM
KyJim's Avatar
KyJim
I didn't look at that....how does that support plate come out ?
