Skip Shift (eliminator)
Old May 18, 2018 | 01:27 PM
IBXGS's Avatar
IBXGS
Default Skip Shift (eliminator)
I'm sure this topic has been all but beaten to death here but... I was all set to get the one that goes inline under the car (next to the M6) then I see this fuse with apparently a resistor in it that does the same thing. Seems the way to go, maybe too easy but I have to ask if I should get the 'fuse' or go with the inline wire harness even tho it's more of a PIA to install? Anyone have experience with the fuse style? BTW: 2013 GS
Thanks Fellas
Old May 18, 2018 | 01:34 PM
itomh's Avatar
itomh
I have the fuse style and have had no issues. Couldn't see why I wanted to crawl under car for inline version.
Old May 18, 2018 | 01:37 PM
IBXGS's Avatar
IBXGS
Exactly my point, unless there was some sort of issue with them. Sounds like your happy with it, thanks
Old May 18, 2018 | 01:41 PM
C6Sal's Avatar
C6Sal
Default I have the fuse fix
Thanks Fellas
I installed the fuse fix about a month ago. No problems...
Old May 18, 2018 | 01:52 PM
Homer3D's Avatar
Homer3D
I did the blown smart fuse way. Worked just fine. I have since tuned my car so skip shift was just tuned out and I put a regular fuse back in.
Old May 18, 2018 | 02:09 PM
jaredtxrx's Avatar
jaredtxrx
Smart Fuse fix here for about 6 months (6k miles). Zero issues thus far.
Old May 18, 2018 | 03:04 PM
IBXGS's Avatar
IBXGS
OK, is there a general consensus on a certain brand or place to purchase said 'fuse'?
Old May 18, 2018 | 03:22 PM
jaredtxrx's Avatar
jaredtxrx
I went to Autozone because it was down the street, and got a multi-pack (10 maybe?) Any 10amp miniblade "smart fuse" should work. Between the blades should be a small opening, i dug my pocket knife in there and brake the link on the fuse.
Old May 18, 2018 | 04:58 PM
IBXGS's Avatar
IBXGS
So all you need is a 10 amp fuse that lights when blown (smart fuse), and not a special one with a resistor built in like I've seen? Also, does it go in under hood box or passenger floor mat box?
Old May 18, 2018 | 06:25 PM
Dano523's Avatar
Dano523
http://xse.com/leres/z06/cags.html
Old May 18, 2018 | 08:49 PM
biker1059's Avatar
biker1059
Had mine tune out by 06montess. Look him up, he can put a good tune on your car
Old May 19, 2018 | 12:24 AM
kevinkar's Avatar
kevinkar
I bought a fuse off of ebay when I got my '05 and had it in for the 4 years I owned the car with no problems whatsoever. Fearing any tomfoolery by any service tech, I always kept the OEM 10A fuse in the console and swapped them out as necessary.
Old May 19, 2018 | 08:34 AM
IBXGS's Avatar
IBXGS
A lot of good info, thanks. I think I'll head to AutoZone later and do this myself. Thanks everyone!
Old May 19, 2018 | 09:05 AM
GARYFINN's Avatar
GARYFINN
From: S/W ,Fla-Ohio State Football isn't a matter of life or death,Its Much More serious than that
1/8" drill and drill out the fuse core EASY PEASY !!!!!!!!!!
Old May 19, 2018 | 09:11 AM
IBXGS's Avatar
IBXGS
So basically drill out the core but leave the LED portion intact correct?
Old May 19, 2018 | 09:26 AM
GARYFINN's Avatar
GARYFINN
All you have to do is drill so that it splits the connection between the 2 prongs
Old May 19, 2018 | 09:28 AM
GARYFINN's Avatar
GARYFINN
If I can do it ANYONE can do it
To Skip Shift (eliminator)
Old May 19, 2018 | 06:19 PM
IBXGS's Avatar
IBXGS
Thanks man, I'll take care of this tomorrow.
Old May 19, 2018 | 10:03 PM
Dano523's Avatar
Dano523
Not a fan of the blown safety fuse, since over time the LED light will burn out and the car will throw codes.
So 10amp fuse swapped with a home made 2.2ohm resistor fuse is the better solution.
Again, click the link before and shows you have to break the fuse link on a 10amp fuse, to solder in a 2.2ohm resistor isntead.
Also, the link shows you the location of where to replace the 10amp fuse with the 2.2ohm resistor fuse.
https://xse.com/leres/z06/cags.html
Old May 20, 2018 | 10:27 AM
Boomer111's Avatar
Boomer111
Easy to have programmed deleted.
