Where to find HUD replacement only for HUD equipped car?!?
I have a 2005 that came equipped with the HUD setup......but pretty sure the pin is broken as it would slip down while driving. Now it's completely out of site.
All I need is the replacement HUD......and not all the other parts associated with adding to a non-equipped HUD car.
Any help in pointing me in a direction of where I can find just the replacement I need?
Thanks!
Thanks!
Check your local junk yards.
Thanks for the reply, but I'm not looking to go that route and end up getting a used one that has the pivot pin probably already worn.
Looking for a new assembly. I remember seeing Gene Culley selling just the display without the associated hardware.....but those threads are years old and I'm not sure if he is still in business.
Received 1,120 Likes
Google 15934351 and start searching for a supplier.
I think Gene is still at Cultrag:
https://www.cultragfactoryparts.com/...splay-15934351
Received 1,680 Likes
Look on eBay.
Thanks guys!
Exactly what I'm looking for. Just dread the installation although it doesn't look too complicated.
I may look into the repairing the one I pull out, and putting it away in case I ever need it.
Well I just looked at it and it says for 2006+ and wont fit my 2005....although I've read somewhere before that it does actually work.
I will try to contact Gene and ask him.
Give your VIN to Gene and he'll double check the part number. I have a 2005 3LT and I used 15934351 Hud Display in mine.
Consider this a data point, and check with Gene or someone to be sure. FWIW, I fixed my old one, and put it in the closet it is part number 10376566.
rmtt,
Thanks.....same car year and options here. I emailed Gene, but seen in one thread tgat his daughter is in the hospital. I've read numerous threads that the part number given above will work....but just want to be sure before pulling the trigger!
Received 3,089 Likes
2021 C6 of the Year Finalist - Modified
Gene just posted here today .... Last post in this thread:
https://www.corvetteforum.com/forums...ts-source.html
