fixed my electrical issues
Old Jun 9, 2018 | 10:53 PM
speedy08's Avatar
speedy08
Default fixed my electrical issues
changed the battery and it all went away. guy at the shop said it was low voltage messing with service acting handling and the issue when the gauges suddenly go dim as your driving. sometimes it took me pressing the push button twice for it to even attempt a crank
Old Jun 9, 2018 | 11:17 PM
owc6's Avatar
owc6
Rinse and repeat as necessary.
Old Jun 10, 2018 | 08:14 AM
449er's Avatar
449er
CF Community Team
A weak battery causes all kind of electrical gremlins on these cars, a common problem for sure
Old Jun 10, 2018 | 08:19 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
If not THE most common problem and the reason mine is always on a tender in the garage.
Glad you got it sorted.
Old Jun 10, 2018 | 06:13 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Old Jun 10, 2018 | 09:32 PM
Panterawill's Avatar
Panterawill
Default Battery
I learned the long hard way to replace the battery when there are odd electrical issues, even if the battery tests good.
To fixed my electrical issues
