C6
Old Jun 16, 2018 | 06:42 PM
Bryan.Elkins's Avatar
Bryan.Elkins
Default C6
Looking for a C6. Are there any years I should avoid?
Old Jun 16, 2018 | 07:08 PM
EVRose's Avatar
EVRose
No.
Old Jun 16, 2018 | 07:11 PM
Reckedhim's Avatar
Reckedhim
What a terribly titled post.
Old Jun 16, 2018 | 07:23 PM
HBsurfer's Avatar
HBsurfer
Originally Posted by EVRose
No.
Old Jun 16, 2018 | 07:28 PM
Bruze's Avatar
Bruze
LOL, here we go . . .
Attachment 48346729
Attachment 48340938
Old Jun 16, 2018 | 08:24 PM
jrose7004's Avatar
jrose7004
They're all good.
Old Jun 17, 2018 | 01:31 PM
gilhuly's Avatar
gilhuly
[CF]buy the newest you can afford[/CF]
Old Jun 17, 2018 | 03:36 PM
Bryan.Elkins
No.
Thanks. Sometimes some years have quirks that get fixed in later model years.
Old Jun 17, 2018 | 03:38 PM
Bryan.Elkins
I got a lot of good information by asking questions here before I bought my C5 Z06. Your suggestion sounds logical.
Old Jun 17, 2018 | 03:44 PM
Vette_DD's Avatar
Vette_DD
No one mentioned the roofs on the 2005s, 2006s, and early 2007s. Roofs had a tendency to turn your coupe into a vert. GM issued a recall and many of them were fixed or replaced. But might be some that got neither.
I had 2 different 2005s and a 2006. They replaced the roof on my 2006 before it happened to me. For other reasons, I didn't keep either of the 2005s very long, so I don't know whether they eventually had the problem or not.
Old Jun 17, 2018 | 04:36 PM
Bruze's Avatar
Bruze
. . . but, if the car has a clear (smoked, see-through) roof, then none of that matters.
Old Jun 17, 2018 | 04:51 PM
Dutch08's Avatar
Dutch08
No problem with either roof (I have two ) on my '05. My advice is don't buy a new 2017/18 new as the depreciation is not worth it. I personally own a c6, but think the C5 in terms of styling ( Seems I'm in the minority opinion on that ) is the best looking.
All Corvettes have "class/type/revision/model" problems as does any vehicle, but overall they are strong reliable vehicles. It has been said here many times.. buy the lowest mileage/newest year model that you like.
Old Jun 17, 2018 | 05:00 PM
h8snow's Avatar
h8snow
I agree 100% about the style of the C5s they have that wide low look. Not all angular over styled like the C7s. Hope that GM smooths out the look on the mid engine C8s.
Old Jun 17, 2018 | 06:39 PM
C6 Snowboarder's Avatar
C6 Snowboarder
I would not anything older than a 2011 ,, just sayin
Old Jun 17, 2018 | 08:18 PM
Bryan.Elkins
Now that's the kind of information I'm looking for. This is especially helpful since I'm primarily looking for a coupe.
Old Jun 17, 2018 | 09:27 PM
OneBadLT123's Avatar
OneBadLT123
Avoid any year besides a 2012. Those are generally regarded as the best year for the C6..... by me
Old Jun 17, 2018 | 10:25 PM
EVRose's Avatar
EVRose
To C6
Old Jun 18, 2018 | 04:44 AM
Gator6977's Avatar
Gator6977
2018 C6 of Year Finalist
Personally, I would avoid anything older than a 2005 and nothing newer than 2013 if I were looking for another C6. But seriously, you can't go wrong with about any year. Just go into any purchase knowing the older the vehicle, or higher mileage, some issues start to surface depending on how it was driven. My advice is to test drive and learn as much as you can about the car from the owner and online. Listen for squeals, vibrations, clinking near or around the center console, check the harmonic balancer, check the tires for wear, inside the rear quarter panels for lots of rubber left behind from heavy burn outs, fill the gas tank above half and sniff around the drivers side back tire to see if the fuel pump is leaking, play with the stereo settings and listen to each speaker independently of the others, etc. A VIN search online is a good start, google the VIN will sometimes pull info, check GM's VIS for recalls done or needing addressed.
Old Jun 18, 2018 | 06:24 AM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
If it helps my 2013 has been trouble free.
Old Jun 18, 2018 | 11:07 PM
kevinkar's Avatar
kevinkar
Unless there's a specific reason to do otherwise (for some one-year special of some sort) the suggestion to buy the newest one you can afford is the right answer. Figure out how much you are willing to pay and work backwards from 2013 until you find one that fits the budget.
If you use the popular car buying websites to search for what's available in your price range, color/body/transmission/mileage preferences, you can generally zero in fairly quickly and save the search and review it every day. One day the car you want will show up or, if you wait long enough, the newer ones will drop in price and you can get an even newer one than what you thought you could afford.
