Replace bushings on auto trans cable
1. To Get Her Home:
Put Parking Break On
Jack Car up on drivers side
Find a friend to press on brake (i couldnt find one so used a rock as a chock just in case)
slide under car and find the lever beside the transaxle and swing it/push it all the way forward ( you will have to use the paddles to shift)
Get her home, put on parking brake, turn car off.
2. Go To Autozone and Many others who carry the Dorman kit #14041 bushing kit (DO NOT TRY ANY OTHERS BECAUSE THE SHIFTER BUSHING WILL BE TOO LOOSE)
2a. remove the two T15 screws and 7mm nuts inside the console, then lift the brake cover up and remove those 2 bolts holding the side panel, move shifter to middle and pull up on console cover and pull back near the radio and ac vents, disconnect the cig lighter that is in the console under the cover and your sport control cable. they both have little push retainer tabs, next unplug the left seat heater plug. move console cover up and to the right to uncover shifter.
2b. pull up on cable attached to shifter housing and unplug connection to shifter. Remove the 4 bolts on shifter and pull up. Pull up on shifter cable and it will give way off the bracket you cant see. Replace that bushing, attach shifter and install everything.
3. Jack Car up like in step 1. Un-bolt the metal gas tank shield, like 4-5 bolts. This will give you plenty room. Make sure shifter in car is in park. Use long nose vise grips AND A SMALL SHORT METAL SCREW THAT FITS THROUGH THE BUSHING to press the busing in.
thats it, took me 30mins total for both.
