replacing the stock nav/stereo unit
#61
Received 1,636 Likes
One way to do it is to cut the microphone off the end of the Kenwood mic and run the wire up to the factory microphone. Cut the factory connector off and solder the Kenwood wire to the factory mic. You would lose OnStar doing this but everything on the new HU that requires voice should work.
This is the factory microphone.
There was an upgrade to the microphone by GM later on but it still has the same connector on it.
#62
That would make sense, but I heard that it doesn't work with the C6 mic for some reason. I'm not sure why, but I remember researching it when I was installing my head unit. Most of my information was through the forum, so there is a possibility something was incorrect but I couldn't find any examples of someone doing it successfully. My guess is, what you described is what the installer did with Northshore3LT's car. Maybe his update will help clarify the confusion.
#63
I started because I wanted a back up camera. can't do video with the stock unit. Selected the Pioneer, very happy with it in my 2010 C6. used stock microphone and stock GPS antenna (with some splicing). Better sound, better GPS and back up camera. Very happy with the results.
#64
Thanks for this information. I can't say how many times this question has come up on the forum, and it was always answered with "you need to install the microphone that came with the unit" or "you can't re-use the factory mic". So much so, that I was sharing that info also. Glad to have some new info and alternate options. Thanks to OhBoy and Evrose, and JMaci also for sharing.
#66
#67
#69
This has come up multiple times recently about Crutchfield saying a head unit doesn't fit. Just buy the head unit. Others have installed it without issue. I installed an 8200 which is almost identical in dimensions to the 8400.
#72
Here you go.......Kenwood DDX9705S with capacitive screen. Disappointed in the lack of visibility in top-down sunlight. I have adjusted the contrast and the screen tilt angle, but it is still hard to see in direct sunlight. When I first installed the head unit only, I thought it sounded pretty good in the garage and driving with the top down. Not really any louder than the stock Bose system, but you can do what seems like an infinite number of sound adjustments. First time I hit 55-60 with the top down I knew I needed an aftermarket amp. I went all out and replaced everything and have not looked back. The amp made a HUGE difference, the punch behind the music at highway speeds is night and day difference. Other than sunlight visibility, I really like the Kenwood. In my opinion upgrading the entire system and getting rid of all the Bose components is the best and most enjoyable upgrade/improvemnet you can do to a C6. It is something you use every time you are in the car. I really did not mind the stock Bose system but I wanted to add front and rear cameras, have navigation , bluetooth music and phone, and a more modern look. Spent some money, the install was a learning experience, not really that hard (plenty of Corvette forum help) and have had no regrets.
#76
I thought the units with swivel screens would take care of this problem but apparently not. The navigation is my main concern with a new head unit. Thanks for the replies.
#77
#78
On a positive note........I use the Waze app with Apple Car play for most all my navigation. You will receive audio instructions while your music is playing. The verbal directions are quite good with Waze. With the verbal directions, traffic updates, obstruction warnings, and police reports you almost do not need to take your eyes off the road to look at the screen.
#79
Received 3,087 Likes
2021 C6 of the Year Finalist - Modified
Today I had my installer put in a Kenwood DNX874S Mutimedia Receiver with built-in Garmin Nav in my 2011 GS.
Here is what I found out today after getting this head unit installed that does not make me happy ...
In my other car, I have mobile Garmin "Drive 60LM" GPS. This GPS can be moved from one car to the next if needed. This GPS comes with free map upgrades for life. Usually a new map update comes out about once every 6 months.
So, since my Garmin "Drive 60LM" GPS has free map updates, I thought that the Garmin Nav in my new Kenwood head unit would too .... WRONG !
I just checked today to see if there was an update now available for my new Kenwood / Garmin .... Yup, there sure is .... and it costs $70 to download it !
I had no idea ! !
_________________________________
Kenwood, Mutimedia Receiver with Garmin Nav . . . DNX874S
6.95” Motorized LCD Capacitive Touch Screen
Built-In Garmin GPS and HD Radio Tuner
Plays CD, DVD, SD and USB Flash Drives
Apple CarPlay and Android Auto Compatible
Pandora, Spotify and Sirius XM Ready
Bluetooth Hands-Free Calling and Audio Streaming
13-Band Equalizer with Digital Signal Processing
Front and Rear Camera Inputs
____________________________________
I had no idea ! !
