2005 getting zero power
Old Aug 19, 2018 | 03:40 PM
Jdlawrence3's Avatar
Jdlawrence3
7th Gear
Default 2005 getting zero power
So my 2005 base is getting no power at all. Won't lock/unlock, go to accessory, nothing. I have cleaned the terminals and checked the battery ( 1 year old AC Delco). Mods consist of vararam intake, cam, lg long tubes and x pipe. I've read about the steering column lock (mine is unlocked) being a problem. Also have read about the starter solenoid getting too hot from long tubes. Any help?
Old Aug 20, 2018 | 12:41 AM
Cherokee Nation's Avatar
Cherokee Nation
For sure it is not the starter solenoid.Stay connected you will get more to chime in.
Old Aug 20, 2018 | 07:44 AM
z06clif's Avatar
z06clif
Try disconnecting the battery for awhile. Sometimes a reboot is neccessary.
Clif
Old Aug 20, 2018 | 09:07 AM
FatsWaller's Avatar
FatsWaller
Well since no one else has chimed in yet, how about a bad / broken / disconnected ground? An easy check would be to measure the voltage across the battery terminals, and then measure the voltage from the +ve terminal to a grounding point on the frame or engine. If the ground is OK, you should get the same voltage reading. Alternatively, you can measure the resistance from the -ve terminal to a grounding point. You should get 0 ohms resistance, or very close to it. If it is a ground problem, there are a number of posts on the forum on how to correct that.
Old Aug 20, 2018 | 09:34 AM
Jdlawrence3
7th Gear
After checking the battery a second time, it only read 2v. I hooked it up to a charger and it said it would not take a charge. I purchased a new battery and everything worked fine. It was weird because the first time I checked it, it was fine. Ill see if it becomes a reoccurring problem. Thanks everyone!
Old Aug 20, 2018 | 09:43 AM
Landru's Avatar
Landru
Sounds like a simple case of defective battery assumed good.
Glad it got resolved before chasing rabbits down $ holes.
Old Aug 20, 2018 | 09:57 AM
JasonAndrew's Avatar
JasonAndrew
Did you forget to park in reverse, (manual cars)? I did the same thing once.
To 2005 getting zero power
