Control Module Communications Bus Off is code U0073....It may be the connectors under the passenger foot well. could be loose...Take a look and re-seat them. You can erase the code with no issues with a scanner. See if it comes back
Thanks, will do, might be a couple of days.
Originally Posted by crusher1
Hmmm. Just found this...Could be the the transmission connector harness. A backed out terminal
I saw that the other day when I Googled the error code. Where, pray tell, is that connector?
I cleared the codes before going to lunch which is about a 14 mile round trip. Still okay.
A couple of things: When I turned the ignition on, the DIC said batt was 11.9 V. A hand meter right on the posts shows 12.85. When I first started it I glanced at the DIC and it showed the "Service Traction . . . " message for less than a second then went away. After that, all the way to town and back nothing unusual showing anywhere.
I just did a load test on the batt, shows to be very good.
I'm going to the watering hole for tacos and beer tonight, we'll see what happens.
Ha, yes I've read the countless threads here about the bizarre things that happen when the battery goes out on these cars. It happened to me four years ago -- wouldn't crank, DIC went crazy, lights flashing, etc. Luckily I was in my front yard.
Although the battery is four years old, it is always on a tender when home. I load-tested it this spring and it was still excellent. So, who knows?
Nah, I can't go that route. I have to have things correct. It's part of my (flawed) perfectionism.
Thanks Tony. Do you think the light would go out if I changed my underwear? Last time I changed them was when I bought the new battery. Maybe they're due.
Yep...I know all about that MBPS dis-order (Must be perfect syndrome)....i've had it all my life. I even have to have the door pockets working correctly.....LOL. A piece of tape covering up the light is a no-no. Good Luck and be sure and let us know what you find out cause i'm sure more of us will get bit by the problem.
Eh, got about a mile away from home and the light came on again. Imma let her sit til next week when my buddy can check it with his good scanner.
For news on "The Watering Hole" and the new barmaid, click here for info on who she is, and go to my update on post #197 below the above link.
These cars sure can have some strange quirks. Last year I did a major engine compartment detail getting our car ready to put in a big Corvette show at a GM dealer and club sponsor. As soon as I started the car after the detail I had the check engine light come on with a fault code indicating "high intake air temperature" WTF? Luckily I had just recently received the Tech2 clone that I purchased and was able to retrieve and clear the code. It has been a year now and no more codes have come up since.
My daughter also recently had an air bag fault code set on her Chevy Cruze that resulted from trying to crank the engine with a low battery that resulted from her kids playing with the dome light and leaving it on. The rapid clicking of the starter solenoid triggered the air bag fault and it required a Tech 2 to cancel that fault as well.
Update: So I scanned again and this time the code was P0449, which is the evaporator canister solenoid. I took it to Advanced and they came up with the same thing. They had one in stock, was $30-something, but it was broken.
So at least I know what the problem *probably* is. I'll wait til my buddy gets back in town; he has a lift and this part, from what I've read here on CF, is underneath towards the right rear wheel. Also could be a fuse, which I will check before I do anything else.
Glad it worked out and you got it fixed.
I think Im going to start looking for one of them Tech II. You never know when...
My $20 scanner pulled the correct code, but I couldn't find anything specific about what to replace. Autozone pulled the correct code for free of course, and referenced what turned out to be the bad part (so far anyway, I need to drive it more). My buddy's scanner got the same results so that's the part he replaced.
The worst part of this particular problem was the labor. That thing is buried in the tunnel underneath the car. Part of the exhaust had to be removed, and even then you don't have open access to it. My buddy had a couple of specialized long pliers that made the job somewhat easier than it would be without them.
