Won't Crank
Old Aug 24, 2018 | 12:16 PM
Efendi007's Avatar
Efendi007
Default Won't Crank
Bought my first corvette. A 2005 convertible with a manual transmission and 62k miles. Love the car. There is an issue where the car will sometimes not crank. It just clicks and throws weird warnings. Sometimes it tells me no fob detected even though the key is in the slot in the glove box. I checked the battery and it is fine. I tightened the terminals and plan to change the cables this weekend. Previously I would need to jump the car with another vehicle to run. I read on the net that pumping the clutch may help. This morning the car clicked again so I tested it. Pumped the clutch three or four times and it started right up. What is that?
Old Aug 24, 2018 | 01:16 PM
919cw313's Avatar
919cw313
2018 C6 of Year Finalist
Still sounds like a bad battery or cable to me.
Old Aug 24, 2018 | 01:27 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Or a bad ground... My C6 is relatively new to me, but the C5's were notorious for getting crazy with a low battery.
I always kept my C5 on a tender and now I do with my C6.
Old Aug 24, 2018 | 01:48 PM
HBsurfer's Avatar
HBsurfer
How did you check your battery? If you didn't have it load tested, you should. Most auto 'arts stores will do it for free
Old Aug 24, 2018 | 02:49 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
C6's, especially the earlier years, are notorious for throwing error codes & having other faults when the battery starts going bad. You don't say how the battery was checked nor how old it is, but as an '05 owner since new, it's really important to keep the battery on a tender anytime the car is not used for a couple of days or more. If you don't know the age of the battery, my first suggestion is to replace it with a good, hi-quality battery. My original Delco lasted 7 years & was still good when I replaced it with an Optima Red Top. I've always used a tender (not a charger) even when just parked overnight. As a couple of others mentioned, also check all the connections, both at the battery terminals & at the starter & engine ground. Finally, are you aware that the manual '05's (and only the "05's) need to be shut down with the tranny in Reverse? If not, the electronics don't shut down completely & there will be parasitic drain on the battery. This condition was remedied from '06 on. Let us know how you ultimately make out. And by the way.....the clutch has nothing to do with the starter circuit....just a coincidence.
Old Aug 24, 2018 | 02:54 PM
Efendi007's Avatar
Efendi007
Took it to Advanced and had them do a battery test.
Old Aug 24, 2018 | 02:58 PM
Efendi007's Avatar
Efendi007
The battery is Optima Red Top 2 years old. It was kept on a tender getting trickle charge. I do keep the vehicle in reverse. The clutch thing was super weird and I only attempted it because I read it in a comment under a youtube video. As weird as it sounded it worked this morning when the car told me "no fob detected". I plan on changing the battery cables this weekend. We will see if it goes away.
Old Aug 24, 2018 | 03:07 PM
Jeff T.'s Avatar
Jeff T.
Was it tested, or load tested??
Old Aug 24, 2018 | 03:09 PM
Efendi007's Avatar
Efendi007
Dude attached a machine to the battery and got me to start the car. He said it was getting over 700 cranking amps and proclaimed "the battery is good". I am no mechanic so I took it to mean the battery is good and I don't have to worry about it.
Old Aug 24, 2018 | 03:28 PM
Jeff T.'s Avatar
Jeff T.
OK, just want to be sure...
Old Aug 24, 2018 | 03:31 PM
Efendi007's Avatar
Efendi007
I honestly didn't know the difference so I explained exactly what the guy did.
Old Aug 24, 2018 | 03:48 PM
Jeff T.'s Avatar
Jeff T.
Video of a quick test with a multimeter.
Old Aug 24, 2018 | 05:41 PM
lovinmyls1's Avatar
lovinmyls1
On my 2005 I learned that I have to peg the clutch to the floor to start. If not the gauges sweep and then nothing happens. I could get lazy with my old Trans Am but not the Vet. I also get no fob if my cell phone is in the same pocket as the fob. Just some fyi.
Old Aug 24, 2018 | 08:02 PM
dpigguy's Avatar
dpigguy
Do a forum search on clutch switch. There is a switch up under the dash that is compressed when the clutch is disengaged to allow a start. Known for get misaligned over time and unless the switch is compressed, no start. Might be your issue since multiple clutch movements allowed a start. Just a thought.
Old Aug 24, 2018 | 08:19 PM
Efendi007's Avatar
Efendi007
OK. Thanks for the tip. I'll test the phone thing.
Efendi007's Avatar
Efendi007
That would make a lot of sense. But why would it say "no FOB detected"?
Old Aug 25, 2018 | 03:15 PM
dpigguy's Avatar
dpigguy
these cars are do weird things for various and often nonsensical reasons. If battery checks good, and switch is functioning as designed, I would check ground wires, make sure terminals have the correct conical nuts and are tight, ensure all other electronics are disconnected (ie phone, charger, etc), connectors and fuses are all seated properly (check passenger footwell) and that fob batteries are new. Good luck!
To Won't Crank
Old Aug 26, 2018 | 10:18 AM
sobe88's Avatar
sobe88
You checked the car battery, but what about the key fob battery?
Old Aug 26, 2018 | 10:32 AM
crf450x's Avatar
crf450x
If it's "clicking" and showing "weird warnings", it's related to voltage. The clutch switch is fine and so is the key fob. You have a bad battery or a bad connection.
Old Aug 27, 2018 | 09:55 AM
Efendi007's Avatar
Efendi007
The car, when this first started also threw out an error code to "Service TPMS". I read online the Remote Control Door Lock Receiver module also interfaces with the tire pressure sensors. Another article mentioned the RCDLR makes clicking noise and I can hear clicking in the car.
