2008 corvette
Old Aug 28, 2018 | 03:54 PM
VAHS's Avatar
VAHS
5th Gear
Default 2008 corvette
My husband recently passed away and I have his 2008 corvette convertible. It is in need of tires. Currently on the back there are 285/35ZR19 ; on the front here are245/40ZR18. Do I need to have 2 different size tires. If not, what size is recommended for a smooth ride that would give me adequate mileage (65K)? From others' experience, the run flat tires doesn't seem like something I would opt for since I don't drive it often or far. Please help!
Old Aug 28, 2018 | 04:07 PM
GS982's Avatar
GS982
Finalist 2021 C3 of the Year - Modified
C6 of Year Finalist (stock) 2019
2018 C6 of Year Finalist
Sorry to hear or your loss. The tire sizes you described are the correct factory tires sizes. They are different front and rear. The only positive to a run-flat tire in my opinion is that they allow you to get to a repair shop in order to get it repaired. Other than than that, they are more expensive and ride rougher than a non-run-flat tire. If you opt for a non-run-flat, I would suggest keeping a little air compressor in the car so hopefully you would not have to get towed if your ever did get a flat. Michelin are the best in my opinion, but can get pricey. A lot of people also like Nitto and Continental. I would suggest going to tires.com or tirerack.com. There you can put in your model info and search tires available in both front and rear sizes in matched sets. I have also had great experiences both with Costco and Discount Tire having my tires installed. Good luck and enjoy the car, they are awesome!
Old Aug 28, 2018 | 04:41 PM
Mike's LS3's Avatar
Mike's LS3
Sorry for your loss.
As posted, those are the correct stock sizes. I would replace with the same size tires using Michelin Pilot sport 4S non run flat. If a run flat is desirable, Michelin Super Sport ZP's would be my choice. I am not sure if the 4S come in a run flat. Run flats will allow you to drive with a puncture, but with the stiffer side walls delivering a slightly stiffer ride. On my 2008, the original Goodyear run flats had a stiffer ride than when I replaced them with Michelin Pilot Sport ZP's run flats. So, not all run flat tires ride the same, some more stiffer than others. The convenience and safety of a run flat tire is not a bad idea, unless you have confidence in plugging a non run flat tire on the side of a road late at night.
Old Aug 28, 2018 | 06:05 PM
VAHS's Avatar
VAHS
5th Gear
Default tires size
Thanks so much for your prompt and informative reply. Maybe I will reconsider the run flat tire
Old Aug 28, 2018 | 06:08 PM
VAHS's Avatar
VAHS
5th Gear
Default tire size
Thank you. Very helpful information as I consider those brands
Old Aug 28, 2018 | 06:22 PM
Pilgrim86314's Avatar
Pilgrim86314
I'm on my second set of Continental DWS (Dry,Wet,Snow) tires in the appropriate C6 sizes. The first set delivered ~40,000 miles and this set will probably do the same..
My driving style is high-speed highway, with some semi-aggressive driving on mountain curves. No track or other racing.
Kent
Old Aug 28, 2018 | 07:13 PM
buckmeister2's Avatar
buckmeister2
Generally speaking, Corvettes do not get tremendous miles (65K) from a set of tires. Most folks between 20K and 35K miles. On the plus side, hardly anyone puts 65K miles on a Corvette during their entire ownership. Everything everyone has said is correct. I lean toward non-run flat tires because I want a better ride, and less noise. I seldom go out of town, but when I do, i have my AAA card for potential road hazards, as well as a mini-compressor and plug kit. I never say never...but, have not had a blowout or sudden flat tire in decades, even when I used to drive 50K a year. If you want to consider non-run-flats, there are many good brands, among them Firestone Indy 500's and Hankook Ventus Evo.
If you go to a Firestone store and tell them you saw the Indy 500's on TireRack for $712 for the set, they will probably match it, or come close, plus mounting, balancing, and tax, of course.
Good luck,and I am very sorry for your loss. I am really pleased, and impressed, that you came to the Corvette Forum for help.
Old Aug 29, 2018 | 01:33 PM
GUSTO14's Avatar
GUSTO14
Default Runflat Repair Policy
One other thing I would recommend regarding runflat/ZP tires is that you discuss with the dealer you purchase them from, what their policy is regarding plugging or patching a runflat tire.
Many dealer/tire repair shops will not plug or repair a runflat tire, they will insist on replacing it. I understand this policy from a liability perspective, however it is not one I support. In my view there is no reason that under the same circumstances, a runflat can't be repaired just as a non-runflat is.
Clearly there are reasons any tire should not be repaired, however some shops hide behind the, "oh it's a runflat" excuse when they really are concerned with liability. As long as a runflat is not run for excessive miles with no or extremely low air, it can be repaired safely.
Check with the shop on this policy before ordering runflat tires and if you don't like their policy, go to a different shop and order tires.
Good luck... GUSTO
Old Aug 29, 2018 | 03:54 PM
extrapilot's Avatar
extrapilot
Another option for tire brands are the Firestone wide oval RFT. (run flat tire)
Many owners here use them as well. I have near 50K on mine, a daily driver.
https://www.tirerack.com/tires/tires...e=835YR9FHWRFT
Old Aug 30, 2018 | 06:48 AM
bonnell's Avatar
bonnell
I recently put these on my ‘08 convertible. I’ve had them on another ‘08 vert and I really like them. They ride well and I have peace of mind when I travel.
I am am sorry for your loss. Keep in mind that there are many knowledgeable members here who are happy to help.
Old Aug 30, 2018 | 02:45 PM
Bat66's Avatar
Bat66
I also run Firestone run flat and are very happy with them'
Old Aug 30, 2018 | 10:25 PM
Dano523's Avatar
Dano523
VAHS , My condolences.
As others have said, the tires are the correct size, and the Current OEM type replacements would be the Michelin Pilot sport 4S non run flat .
Now having said this, tires for the vet are only good for about 5 years no matter if worn or not, since at about the 5 year marks the tire rubber gets hard, they do start to go out of round, and the manufacturers tread life warranty expires at this point for the same reasons.
If the your plan is to keep the car, then the above tires would be the way to go on the car.
On the other hand, if you are planning on selling the car anytime soon, then let the new owner install new tires on the car isntead.
Hence the 4S are going to run around $2K for the set, and the warranty for the new tires will be under there name so the can use the warranty.
Old Aug 31, 2018 | 11:00 AM
Mike's LS3's Avatar
Mike's LS3
Currently, Tirerack has the all four stock size Michelin 4S's for $1082.00, less $70 Mastercard rewards card and free shipping to one of their recommended installers. That's a good price for a very good tire!
Old Aug 31, 2018 | 02:34 PM
Dano523's Avatar
Dano523
Very good price, but would need to add in mounting, balancing, and road hazard to the tires to get them on the rims and covered under warranty.
Old Aug 31, 2018 | 02:37 PM
Dano523's Avatar
Dano523
Very good price, but would need to add in mounting, balancing, and road hazard to the tires to get them on the car and covered under warranty.
But sometimes you can take such pricing into discount tire, to get them to drop the price of the tires with all the above as well.
Old Sep 2, 2018 | 10:28 AM
RobJoy's Avatar
RobJoy
You're not going to get 65k miles on any tire on the C-6. Expect 15-20k tops. This may help you decide how much you want to spend on tires that aren't going to last all that long. Some say they get a lot more mileage but they probably lost track of how many tires they've bought.
Old Sep 2, 2018 | 12:03 PM
Dano523's Avatar
Dano523
Truth is, unless the car is a daily driver, you end up replacing the tires well before they are worn out, from the age of the tire rubber getting hard, and the tires going out of round well before the 6 year mark on the vets.
Due to such. most vet owners could put R888r tires on the vet with a tread wear of 100 to have major grip for street use, and still have to replace them due to age in 5 years, and not treads worn out in that amount of time instead.
Hence I end up LMAO when someone will complain of hard GY F1 tires still on the car, but turn around and stick a 500 tread wear set of tires on the car like the A/S3's as the replacement set for their garage queen, with not plans of every driving the car in adverse conditions to begin with.
Old Sep 2, 2018 | 12:19 PM
Mike's LS3's Avatar
Mike's LS3
Besides tire compound, it depends on how and where you drive. I drove 30k, mostly freeway miles with Michelin PS2 ZP's. I was actually surprised! My second set of the same tires with more mixed driving, only 25k miles. I find Michelin tires offer a good balance between tire wear and performance.
Old Sep 2, 2018 | 03:04 PM
rmtt's Avatar
rmtt
I'm running this exact tire and love it. Always get great mileage from them, and they are of of the more quite RFT's I've bought.
To 2008 corvette
