Power window Does Not Go Down All the Way
I have searched the Forum but did not find any information. My 2011 Convertible sat in the garage for nearly three weeks while I was on a vacation. I returned home yesterday and the car started up with no problem. I thought I would take it out for a ride and dropped the top but discovered the passenger side window will not go down all the way. I am hoping someone knows how to correct this, saving a trip to the dealership.
I have searched the Forum but did not find any information. My 2011 Convertible sat in the garage for nearly three weeks while I was on a vacation. I returned home yesterday and the car started up with no problem. I thought I would take it out for a ride and dropped the top but discovered the passenger side drivers window will not go down all the way. I am hoping someone knows how to correct this, saving a trip to the dealership.
Just had the exact opposite problem today. Friend who was a GM Corvette Tech. told me to unhook the battery for 30 mins, and then give it a shoot. Worked like a charm; did have to re-index the windows, but the clock remained set. Hope this helps.
45gunner (09-02-2018)
I tried reindexing the window twice with no solution. I will try unhooking the battery later today to see if that works.
Sorry for the earlier confusion. Typo. It is only the passenger side window that does not go all the way down.
Cherokee Nation (09-03-2018)
I had the same problem on my 08,but since you did not answer my question in post #5 I can not tell you what my fix was....Good Luck
Sorry I missed your post as I was in a hurray. My apologies. Glad to see you are so eager to help out fellow Corvette Owners.
Race Car Tech
I had the same issue on the passenger side. It was the window regulator cable that was frayed and would bind up and would not allow the window to move.
I replaced the regulator and problem was solved.
I have a PDF of the change out of the regulator if anyone needs it.
cornel02 (09-05-2018)
