2008
Old Sep 9, 2018 | 02:51 PM
3REDZ's Avatar
3REDZ
5th Gear
Default 2008
Passenger door would not open from the outside. replaced the door handle pad, worked fine for about a week, then the same door would not open from the inside or outsode. Is there a lock acutator or what other component is not functioning?
Old Sep 9, 2018 | 11:02 PM
jrose7004's Avatar
jrose7004
It would probably help if you would state the problem in the thread title instead of you cars year.
Old Sep 10, 2018 | 12:44 AM
Cherokee Nation's Avatar
Cherokee Nation
The lock in the B pillar (Door Jam) could be bad......Common problem.I replaced my drivers door lock in my 2008 last year and it had the same problems as yours.
Old Sep 10, 2018 | 12:48 PM
3REDZ's Avatar
3REDZ
5th Gear
Did you purchase from GM or aftermartket? if aftermartket do you recall where you bought it and what it costs?
Thanx,Jim
Old Sep 11, 2018 | 12:09 AM
Cherokee Nation
Thanx,Jim
I get my OEM parts from.....GM Parts Direct.....Google GM parts and you will find many places to get OEM parts even Amazon.
Old Sep 11, 2018 | 02:52 PM
HOXXOH's Avatar
HOXXOH
I also replaced the latch assembly in my '08 last year. You don't need the cables, since it's easier to keep the OEM ones in place. The assembly is in the $150-200 range and takes about 2 hours to replace the first time, but I suspect about 30 minutes after you done several.
Old Sep 11, 2018 | 03:33 PM
stingray71's Avatar
stingray71
This is a duplicate post to the other one which has a lot of information...
https://www.corvetteforum.com/forums...008-coupe.html
Old Sep 11, 2018 | 06:04 PM
drewz06's Avatar
drewz06
thing knower
just had this problem it was the window regulator
open the door manually very carefully, turn on the car and see if the window will roll down
this ecu will not allow the door to open if the window can't index down, none of door buttons will work
does the red door lock light flash when you try to open ?
Old Sep 11, 2018 | 11:16 PM
3REDZ's Avatar
3REDZ
5th Gear
the window indexs when attempting to open the door. The window goes up and down . the red light does flash
Old Sep 11, 2018 | 11:21 PM
3REDZ's Avatar
3REDZ
5th Gear
I have keyless entry, the lock mech only has one cable, but u mention "cables". in a youtube post showing how to replace the lock mech it shows 2 cables. I looked several times inside the pillar cavity to be sure the cable had not broken away from the lock mech itself. was your lock a keyed entry or keyless?
Old Sep 12, 2018 | 09:45 AM
drewz06's Avatar
drewz06
thing knower
yeah if you take it to a dealer they can plug the computer in and tell you exactly which mechanism is having trouble, shouldn't cost too much
the light flashing but the window indexing is probably indicating the latch mechanism isn't functioning
can you roll the window up and down all the way without issue?
Old Sep 12, 2018 | 01:16 PM
HOXXOH's Avatar
HOXXOH
All C6's have keyless entry. The latch has two cables. One going to the front passenger compartment on the floor beside the seat and the other for just the driver's door that's located in the hatch a little forward of the gas door release. I found it much easier to disconnect the cables at the latch assembly, than to try removing the latch with the cables and then stuffing the new latch back in with cables attached.
When you press the pad or interior door button, the release is by an internal solenoid in the latch assembly, which is totally independent of either cable.
Old Sep 12, 2018 | 01:37 PM
HOXXOH's Avatar
HOXXOH
Shouldn't but it does. The local dealer charges $120/hr for diagnostics with a 1 hour minimum. Then they want to sell the part for full retail and price the labor in the flat-rate guide, which any mechanic worth his salt can easily beat. If you have tools, you probably have more mechanical aptitude than is needed to change a light bulb. This forum can provide guidance to turn a $600 dealer job into a $180 part purchase and some bonding time with your car.
To 2008
