Transmissions
Trans is not the problem, its the differential case that is the weak point of the drive line instead.
As for auto over manual.
Auto will be faster for strip type use, while manual is better for road course work instead.
Hence Auto will up shift a lot faster, but you can downshift a manual faster that the A6 trans isntead.
As for once you figure out if you need an auto or manual trans, the the trans can be built up to take more power, but again, your back to just how much HP and torque you can throw at the diff instead. Also, if you get into wheel hop, all bets are off since wheel hop can create well more toque to the Diff when the wheels bite during the hp, then the motor can throw at it isntead.
I'm very close to throwing down the money it will be in 06 or newer thank you for tha
Well I threw down I found an 07 with a z51 kit or option it has 34000 miles on it has been Barn fed from a pilot we all know how meticulous Pilots are if you understand what I'm saying I got a chubby
Your confusing pilots, with the A&P's that take car of the planes they fly isntead.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
could you please use some punctuation?
Not So Fast (09-28-2018)
I need a translator thingy!
marinablu67 (09-29-2018)
Supercharger
Well I ordered a Edelbrock e-force 1593 supercharger boy am I going to have fun this winter installing it any advice suggestions helpful hints would be appreciated
This is interesting. On the oil leak. Noticed I've developed a leak in the same place. Have any others found the same leak source on theirs, the filter loose? Will check it this weekend. '08 base LS3
Your profile doesn't say where you live. If you're anywhere near NYC, I strongly recommend considering having Chuck Mosello of Corvettes of Westchester do your installation. Especially during the winter months when he's not hammered by fair weather customers.
