Hard acceleration tripped my SDM module
Old Sep 18, 2018 | 11:21 PM
SladeX's Avatar
SladeX
Default Hard acceleration tripped my SDM module
Funny thing happened while driving. After accelerating hard off a stoplight, I got an airbag light warning. I thought it was a simple seat connector issue, but after inspecting all connections and even getting a tech 2 emulator, I pulled a B0051 code.
Nothing deployed, seatbelts never got tight or anything, I guess it was the SDM going bad or something.
Looks like I will need a replacement SDM.
Old Sep 19, 2018 | 01:01 AM
CHEV AGAIN's Avatar
CHEV AGAIN
I’m reading where a battery disconnect for a couple minutes might reset it. Worth a try?
Mark
Old Sep 19, 2018 | 07:49 AM
C6ToGo's Avatar
C6ToGo
Service manual states: DTC B0051 is a latched code. You cannot clear a latched code. Replace the SDM after following the instructions.
Old Sep 19, 2018 | 08:00 AM
SladeX's Avatar
SladeX
Yeah, I already knew it was a latched code, for fun I took a shot at disconnecting for 30 mins. No change, reader still says B0051, but all other SIR system codes pass so looks like new SDM is what I need. I'll have to check with a dealer for the cost of reprogramming a replacement. Swapping out the unit is easy enough.
I contemplated sending out the unit to be reprogrammed, but on second thought, the unit FAILED rather than a successful deployment so I'd rather not chance a reprogram only for the unit to fail again and actually successfully deploy the airbags on me during a hard stop or quick gear change.
To Hard acceleration tripped my SDM module
