Hence is this video, zip ties where not used to pre compress the shocks, and cause a hell of muscle'g to be to try to compresss the shock once is loose isntead.
Also, on the lower long shock through bolts, grease the bolt shafts before you put them back in.
Lastly, if the upper shock rod rubber bushing rubber set do not look correct, then reuse the old top stock rubber bushing from the old shock if they are in good shape instead.
Yea I can see the zip lock method working just like changing a Harley tire. But be darn well sure that you have enough ties and they are on correctly so as they don't pop or slide on you....or your teeth.....
