Replaced SDM Module
I'll take the car out for a drive to work tomorrow and see if the B1001 code will appear after a drive.
My impression was that any replacement SDM would not work correctly with the BCM until programmed in. Anyone knowledgeable on the quirky 05s to know if you can get away with swapping the SDM with no problems?
As for the replacement sdm, sounds like is came programmed "virgin" correctly, and BCM will marry it from the first GM lan bus check on start up. The Re-sps flashing is more for if the module was pulled out of another car already married, and needs to be remarried isntead with SPS flesh firmware flash.
I guess my understanding was the BCM pairs to the SDM, not the SDM to the BCM. Makes sense now as to what happened.
My concern is why the old one tripped up and got a SDM deployment code in the first place. I'm going to look around to see if anyone locally can read it and get the so called event data which made it think it deployed or if it was a general failure of the part.
