Steering wheel sensor problem
Old Nov 21, 2018 | 08:46 PM
Jay Yarull's Avatar
Jay Yarull
6th Gear
Default Steering wheel sensor problem
Hi i recently change the steering wheel sensor to my corvette c6 2005 , now when i turn to the right or left the active handling stop my car and the abs sounds. What do you recommend because i use the tech2 and i can find the solution for the problem.
Regards
Jay
Old Nov 21, 2018 | 10:48 PM
4SUMERZ's Avatar
4SUMERZ
Regards
Jay
You will need to center the sensor mechanically so you don't get the issues that you are experiencing.
I've attached a PDF file of the procedure (starts on page 165)
File Type: pdf
Old Nov 21, 2018 | 11:06 PM
Jay Yarull's Avatar
Jay Yarull
6th Gear
Thanks for your help tomorrow I check the installation.
Regards
Jay
To Steering wheel sensor problem
