C6 Full Width Rear Spoiler
Moderator
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
Welcome aboard! Check in with the folks on the C6 forum. A lot of good info there, someone may be able to help you.
Moderator
Received 3,622 Likes
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'12-'13-'14-'15-'16-'17, '21
Moved to C6 General
I bought 1/4x20 set screws to fit in the bolt holes for my spoiler, put masking tape on the areas to be drilled, put a little grease on the tips of the set screws, set the spoiler on the car then drilled the holes where the grease spots were. One hint, you will need to drill a couple sizes larger than the bolt. That was the only issue I had, holes were too small. From removing my tail lights to putting them back in with the spoiler on took about an hour and a half, including my drive to get the set screws
Received 3,087 Likes
2021 C6 of the Year Finalist - Modified
BTW ... I don't believe there is an actual template supplied or available for mounting the GM full-width rear spoiler ... Use the video
St. Jude Donor '15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
