Protectant
It fully depends on what you plan on doing with your car. DD,. Garage Queen, occasional road trips, etc.
The Clear bra will definitely protect from rock chips, and sandblasting on road trips. On any Interstate, the median shoulders are full of sand, and other debris that get blown up by 18 wheelers. Never follow them for any length of time. Pass them quickly!! If you are going to do clear bra, make sure you get the side mirrors done as well. Those take a beating...rocks seem attracted to them.
Ceramic will make the shine pop!
If your just going back and forth to local car shows, clear bra is not likely required.
Good luck in your decision.
Good luck, remember your car so its what is important to you.
The best local shop just gave me a $650 bid to remove the old film, prep and install XPEL over the entire nose and headlight lenses. That is a reasonable price and I'll probably end up doing it because I intend driving this car as a DD and on trips. On my silver car the clear film is very difficult to see, nearly invisible.
T
On the other side of the coin, the clear "protective" bra takes the wear and tear, but with age and unlike clearcoat, plastic yellows and becomes brittle. The surface becomes a little dull too because it has taken the beating instead of the clearcoat, but it is much softer than acrylic paint. As the clear plastic ages, it becomes tougher and tougher to remove. 5 years is about the maximum before it degrades in both looks and its flexibility. After 5 years, the plastic becomes more and more permanently bonded to the paint surface.
So, if this is your forever car and probably like Marie Barone in "Everybody Loves Raymond", you want to preserve the couch so someday, after you're gone, someone else will enjoy the new paint, this is probably your mod then.
When I bought my 09 C6 in 15, it had a clear bra that the original owner put on brand new. Taking it off was one of the most miserable experiences I've had...and I used the preferred method of steaming it off like the pros use. If you have the rare opportunity to remove a 5/6 year old clear bra FIRST, before you put one on, then you might vow, like I did, never to put one on in the first place. Instead, I'll enjoy the actual paint, and in 6 years, I'll use the money to visit a pro detailer. With a pro paint correction, you cannot tell the difference next to a car that had a bra on, then removed.
