c-6 won't start.
c-6 won't start.
Good day guy's. Here is my problem. I went out in the car stooped at a store when I got back in it it started went into rev. but then didn't come out. i looked in the console and that was fine so I look under and found the cable off due to heat. put it back on but now can't the shiftier into park to start the car.I have held the neutral safety switch in on the shiftier and it just clicks.Is there any thing in the shiftier that can cause this?
if the shifter cant go into park then the lever on the trans is not in park ?(still in reverse) I know on the 6l80 the electronics(internal mode switch) in the trans will will not let the car start unless it really is in park, no matter what you do with the shifter.
