OEM replacement horn
Old Feb 17, 2019 | 01:26 PM
Kfred 513's Avatar
Kfred 513
Default OEM replacement horn
Hi guys, My horns quit working and blew the horn fuse, which gave me the service charge system error message. I had a hard time finding a factory part number even after searching on Genes website, the FSM, and general google searches. I decided to just pull the factory horn assembly and find a part number. When i finally found the correct horn, they are $51 each, or $35 each for the AC Delco solution. Mine are made by FIAMM, P/N AM80S. The High and Low frequency horns are the same part number but they have an H, or L on the front to differentiate. I found them on Amazon, $30 for the pair. These should work with the factory harness that i removed from my old assembly. If for some reason they don't work, i will report back. Figured this might help someone in the future.
