Its $5 at walmart, but dont look in electronics, they are in the check out area with lots of other phone stuff. Mine worksf well, 2010 base, has aux jack input.
I am able to talk over Bluetooth on my iPhone with it plugged into the USB streaming music in my 2012 GS. I can also use the channel controls on my steering wheel to skip songs.
Interesting. Wonder if this is a setting on the phone?
Agree with BMF_C6, the BT45-Vette is great unit and easy to install. Have had one for several months, no regrets, also purchased from Amazon. Good luck.
No cutting!! Unit comes with wired harness, just make sure you follow included instructions.
The USA SPec BT45-VETTE is a Bluetooth integration kit that is designed to plug into the XM receiver connections in select Cadilllac, Chevrolet, and GMC vehicles. Once installed, you'll be able to seamlessly stream music and phone calls to the factory sound system in the vehicle while being able to use the factory radios buttons and steering wheel controls to change songs, answer phone calls, use voice dials and more.
The BT45-VETTE is a unique kit as it's one of the first designs that allow you to connect into the satellite receiver. This helps save time and money for installation by having the ability to plug into the trunk, glovebox or center console rather than having to tear the dash apart so that you can pull out the radio.
