ECU went out
Old Feb 27, 2019 | 01:10 PM
ChefMark's Avatar
ChefMark
Default ECU went out
Check engine light came on then warning Suspension System Service. Took it in and they tell me the ECU went out and needs to be replaced, I trust the dealer but.....
Anyone else run into this issue? Also had small oil pan leak
Old Feb 27, 2019 | 01:42 PM
the kid C6's Avatar
the kid C6
I had to replace my ECU. My oil pan shows a little seepage, but it's not bad enough to repair at this time (kinda pricey).
Old Feb 27, 2019 | 02:27 PM
Oldguychuck's Avatar
Oldguychuck
What did it cost to replace the ECU?
Old Feb 27, 2019 | 02:58 PM
ChefMark's Avatar
ChefMark
Have not go it back yet? He told the estimate but I blacked out from the cost of the oil leak.
Old Feb 27, 2019 | 04:21 PM
Bsull's Avatar
Bsull
My ECU went out last summer. Cost about $1K for part, programming and installation. I have the old ECU.
Old Feb 28, 2019 | 03:25 PM
Oldguychuck
Thanks for the cost estimate...
Old Feb 28, 2019 | 03:57 PM
LS14ME2's Avatar
LS14ME2
Best time to do the oil pan leak gasket is at the time you do the HB replacement as you have to move all the same crap out of the way.
Old Feb 28, 2019 | 09:37 PM
87SAM's Avatar
87SAM
I be would looking for a second opinion first (2nd 1st, that sounds goofy). Point is, I would want to confirm that ECU that is actually toast.
To ECU went out
