This going to a problem?
Old Feb 28, 2019 | 07:41 PM
Vette9c6's Avatar
Vette9c6
Default This going to a problem?
I will be bringing her home at end of month. Is this going to be a big problem or can I go over at angle or backwards and make it? I saw some of the rubber ramps you could buy that might help. Wondering your thoughts with experience.
Old Feb 28, 2019 | 07:44 PM
Dr Bee's Avatar
Dr Bee
I've had to become an expert for the same reason. Use a 45 degree angle in and out. If that doesn't work there are lots of aftermarket products on the interwebs used to "soften" curbs/driveways for this very reason.
Old Feb 28, 2019 | 08:03 PM
Bruze's Avatar
Bruze
Heh, living in the woods, this isn't a problem I have to deal with.
Old Feb 28, 2019 | 08:06 PM
WICKEDFRC's Avatar
WICKEDFRC
Move.
Uour driveway don't look bad. Take the Vette in and out on an angle.
Old Feb 28, 2019 | 08:10 PM
Bruze's Avatar
Bruze
Originally Posted by WICKEDFRC
Move.
I wonder why Dr. Bee didn't think of that?
Old Feb 28, 2019 | 08:13 PM
wdwinder's Avatar
wdwinder
St. Jude Donor '24
Similar problem in my hood. got 4, 3/8" 18"x48" steel plates. Moving trucks didnt even bend them and water will flow under neath.
Old Feb 28, 2019 | 08:27 PM
saplumr's Avatar
saplumr
Wow! I imagine that looks really good.
Old Feb 28, 2019 | 09:13 PM
slow_zo6's Avatar
slow_zo6
That doesn't look too bad-you should be alright.
Old Feb 28, 2019 | 09:42 PM
marinablu67's Avatar
marinablu67
Yes, it's a problem! We have them all over Florida, along with speed bumps. Take it at an angle real slow, but the splitter is still going to scrape even though. Read your manual, Chevy says it's normal.
Old Feb 28, 2019 | 09:58 PM
DAMCars's Avatar
DAMCars
That will not be problem if taken at an angle. This is especially true if you are stock ride height.
Old Feb 28, 2019 | 10:01 PM
vett_guy's Avatar
vett_guy
You'll probably scrap some...but as others said...angle it in and out....or ramps....
Old Feb 28, 2019 | 10:19 PM
farmington's Avatar
farmington
My drive looks worse than that one. I always back in without a problem. Maybe a minor touch of the plastic air dam. Same pulling out but the going at an angle does work.
Old Feb 28, 2019 | 11:23 PM
hawkgfr's Avatar
hawkgfr
You will be ok just angle her in and out one wheel at a time. When you scrape you want the center to scrape it'll fold back a little...just don't **** your pants the first time you hear the noise.
Old Feb 28, 2019 | 11:30 PM
Dr Bee's Avatar
Dr Bee
I remember the first time I heard that noise...... had to change my tighty-no-longer-whities right away
Old Feb 28, 2019 | 11:41 PM
myredhead1's Avatar
myredhead1
My neighborhood added a few monster speed bumps earlier this year. I’m lowered with side skirts.......I have to drive a little off of the road, then immediately turn on an angle and idle over to get the minimal amount of carbon side skirt scraping.
Old Feb 28, 2019 | 11:49 PM
owc6's Avatar
owc6
Yep, it's a noise to wake the dead!
OP, I used to have to navigate a driveway even worse than this, once a week, for many years, and the only way I was able to do it with any of mine was approach it from downhill at an angle. When pulling out, do the same in reverse, back your *** out downhill at an angle at the change/street, and head up the street, starting out on the wrong side of the street.
If there is a turnaround up beyond the pic, then when you leave head downhill at an angle. Either way, the end of the car reaching the street first should be downhill.,
Hopefully, this is a quiet street, where you can do this.
Old Feb 28, 2019 | 11:50 PM
jimijam's Avatar
jimijam
As a taxpayer, you should call the city or county responsible for that street and have them raise it about 6 inches.
To This going to a problem?
Old Mar 1, 2019 | 06:58 AM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
That looks to be the same as my driveway. Pulling in nose first at an angle is mostly okay, but backing out at the same angle, or obviously nearly so, almost always is a small scrape to the air dams.
What has worked for me is to BACK in at an angle. No scrape. Go easy when leaving as you step down the curb on the way out at a slight angle as well - no scrape.
Old Mar 1, 2019 | 07:12 AM
GUM3Y's Avatar
GUM3Y
I bought a set of ramps from a company called PYLE off Amazon. You need two. Just over $100 each with free shipping. I absolutely needed them and my driveway looks very similar to yours.
Old Mar 1, 2019 | 08:37 AM
449er's Avatar
449er
CF Community Team
For the posters who bought ramps to put on the curb..Do you actually leave them there? I would think that someone would help themselves to your ramps or the snow plow truck would wisk them away when cleaning the front street
