Using my quick jack
Old Mar 11, 2019 | 12:22 PM
BigMonkey73's Avatar
BigMonkey73
St. Jude Donor '15
Looks like same price
Old Mar 11, 2019 | 05:29 PM
HobbesTiger's Avatar
HobbesTiger
They are well worth it. I bought the 5000SLX through Costco. Cost me $999 plus tax, but the shipping was free. Used a credit card that had a 5% cash back promo for warehouse stores and that saved me an extra $50. I use them constantly and am very happy. Worth the $1K.
Old Mar 11, 2019 | 06:36 PM
slammin86's Avatar
slammin86
Anyone have any pictures of their corvette on one? Curious to see the actual clearance everywhere.
Old Mar 11, 2019 | 08:30 PM
Fletch F. Fletch's Avatar
Fletch F. Fletch
Here you go...
Old Mar 12, 2019 | 12:03 PM
RogerRamjet21's Avatar
RogerRamjet21
When you guys (or gals) are working under the car with one of these, do you feel safe or do you also put jack stands in?
Old Mar 12, 2019 | 03:33 PM
Fletch F. Fletch
In the fourth and fifth pics above, you can see the wooden blocks of 2x12s I put under the wheels just as another margin of safety. Actually, I added two more 2x12 pieces to each of them so now each of them are five 2x12s stacked and screwed together.
Old Mar 16, 2019 | 04:26 PM
TorchRed427's Avatar
TorchRed427
Here is a vid of my first use of the Quickjack. Very easy to use.
Old Mar 16, 2019 | 04:39 PM
03BlkZ's Avatar
03BlkZ
The quick Jack worked flawlessly! So happy I bought one. I did my oil change, brake pad swap and new tires while on the lift.
Old Mar 16, 2019 | 06:08 PM
phileaglesfan's Avatar
phileaglesfan
How much does a set weigh? We might be moving soon. I'm guessing they are stable when the car is up in the air.
Old Mar 16, 2019 | 07:00 PM
03BlkZ's Avatar
03BlkZ
They are pretty heavy. I think my 7000slx is about 90 lbs per side. Yes the car was very stable while on the lift and in the down lock position. I felt safer than Jack stands for sure but if I was doing significant work I would probably still pu a stand under for extra safety backup.
Old Mar 16, 2019 | 08:54 PM
TorchRed427
I have the 5000slx and the frames are about 76lbs each and the pump/motor is about 35lbs. Car is very stable in the air. I put my Vette up to full height of 20” or so and tried to move car. It would barely move.
Old May 5, 2019 | 08:11 AM
nmalik3000's Avatar
nmalik3000
Originally Posted by Fletch F. Fletch
Here you go...
Thanks for sharing those pics! With side skirts on the car, is there enough clearance to slide the quick jack underneath or do you need to manually jack the car up first to get clearance? My car is lowered slightly and I plan to add sideskirts, so not sure if I could simply just slide the quickjack underneath?
Old May 5, 2019 | 05:11 PM
  #33
Fletch F. Fletch
There is enough clearance. I have stay-in jacking pucks installed and there are no clearance issues. Just slide underneath and voila-- good to go.
Old May 5, 2019 | 05:47 PM
  #34
Dutch08's Avatar
Dutch08
I wanted a 2 or 4 post lift, but don't really have the space/garage for it.
Wasn't sold on Quickjack but bought one anyway (5000SLX) . Now several oil changes later, clutch replacement, and details (like adjustments, wheel removal, etc.) this is an awesome product. At the highest lift I know I could do anything.
Downside, its a bit heavy to position under the car (I'm not as young as I pretend to be). What I do it to get close and raise the QuickJack to just barely below the pucks. Re-position the rubber blocks to the exact location and raise the car.
Stack them against the wall when (horizontal) you're done, you can still open the car door over them.
Old May 5, 2019 | 07:44 PM
  #35
jashmore1234's Avatar
jashmore1234
I get these recently. They are a must for any QJ owner:
