Trim height bolt question
Ground to fender arch:
LF 26 1/16”
LR 28”
RF 26”
RR 28”
Ground to rocker next to jack/puck point:
LF 4 3/4”
LR 5 1/4”
Ground to rock as close to wheel as possible:
LF 4 3/8”
LR 5 1/2”
I'm assuming the ride height may have been modified pre-me, but maybe not.
Based on the specs in other threads, the rake should be 1.3" max, although I'm not sure I need to bother with it. If I do, I'd either need to raise the front or lower the rear. I took photos of the trim bolts on one side. The rear bolt seems max lowered, but I don't know for sure. Before I start messing with things does anyone know if that rear bolt has further adjustment based on the photo? (I couldn't find a photo of a fully lowered bolt anywhere to compare)
I like the look of the front although I do need to be careful with the clearance. It would be nice visually if the rear came down just a little more. However, I don't want to cut ribs off the bolts.
Front trim bolt
Rear trim bolt
Current stance
Can't comment on your specs with out referencing the service manual.
But can comment perhaps the 1/2 difference left to right is fuel load?
I'd get a full tank of fuel and then remeasure.
IMO You are definitely correct measuring frame to ground...congrats.
Good luck.
From what I understand cutting 1 rib is good for 1/2", which would put me at 27.5" in rear with a full tank of gas. That's assuming the bolts are maxed out right now. That would give 1.5" of rake between the P and R measurement, same as you.
So I either leave things as is and live with the current rake, raise the front 0.5" (~6 turns??? ) to reduce rake, or cut a rib at rear to reduce rake.
Here's a photo of what the trim bolt looks like when fully lowered. As you can see there was more to be had.
OE parts allow???
What do I buy , Where do I learn how to lower rear of my 12 Grand Sport if Im not
happy with all that the stock Bolts/Rubber allowed me???
P-Height: Top of front wheel arch to ground
R-Height: Top of rear wheel arch to ground
Z-Height: Vertical distance from center of the ball joint housing bottom surface to the center of the front lower control arm front bolt (threaded portion of the bolt)
D-Height: Vertical distance from the centr of the ball joint housing bottom surface to the center of the rear lower control arm front bolt (threaded portion of the bolt)
Model: Base (1YY07) RPO: FE1
P-Height: 27.4 in +/- 0.39 in
R-Height: 28.74 in +/- 0.39 in
Z-Height: 1.90 in +/- 0.39 in
D-Height: 4.53 in +/- 0.25 in
F-R Rake: 1.34 in
Model: F55 (1YY67) RPO: FE2
Same as FE1
Model: GS (1YY07) RPO: FE3
P-Height: 27.28 in +/- 0.39 in
R-Height: 28.23 in +/- 0.39 in
Z-Height: 1.85 in +/- 0.39 in
D-Height: 4.49 in +/- 0.25 in
F-R Rake: 0.94 in
Model: Z06 (1YY67) RPO: FE4
Z-Height: 1.69 in +/- 0.39 in
D-Height: 4.02 in +/- 0.25 in
F-R Rake: 9.94 in
Model: ZR1 (1YY87) RPO: FE5
Same as FE4
Reference: https://www.corvetteforum.com/forums...im-height.html
F-R Rake: 1.34 in
Same as FE1
F-R Rake: 0.94 in
F-R Rake: 9.94 in
Same as FE4
After 25 miles or so of driving I'm now at 26 1/4" front both sides and 27 7/8" rear both sides. So that turn or two at rear was good for 1/8". It could settle out a bit more. I'm not sure why the front is 1/4" higher now. Even this little bit in rear looks better. I may leave it at that. It's interesting that the spec in front is over 27". It would be like monster trucking since I got used to this.
- The installation of a supercharger added about 100 pounds to the front end.
- When the first harmonic balancer failed, a frozen nut forced a replacement of the front leaf spring.
- Twice I've had the entire rear end disassembled to replace a fuel sensing unit.
- Last summer I had the entire drive line from the flywheel to the differential removed and rebuilt.
Next month after a 100K service on the supercharger, I'm having Red's ride height checked and reset to original factory specs for an FE2.
