Erroneous Check Engine Light
My mechanic speculates that perhaps a rodent chewed on a wire, but before I start trying to chase that down, does anyone else have any better guesses than a chewed wire?
It seems most all of the failing gas caps look fine. A Slant replacement cap seems to be a popular brand. It also may take some driving cycles to clear the code.
On the gas cap isssue, the car checks the purge valve, the canistor solenid, and the tank pressure readings twice every start up. Depending on which of these has the problem, it going to throw a specific code. So the gas cap concept is that the cap is not sealing correctly, and it will be the tank pressure reading that will be off to throw that specific code.
The glitch, when you start the car, the canistor solenoid is closes to seal the tank off that way, the purge vavle is kept closed for a short time to keep the tank sealed off that way, and this causes the differential reading on the tank pressure sensor that allow the two test to pass. Once the tests pass, then the tank is percantge relieved via the purge valve.
So again, could be the canister solenoid valve in the rear that has a problem (burnt out, or one of the two wiring to it has a broken wire/problem in the C186 connector next to the battery), the purge valve in the engine bay at the front of the car that has a problem or broken wire, pressure sensor has a problem, or could be the lines to all the above having leaks isntead.
So to sum it up, the trouble code that is in memory will tell you which part is having a problem, it can be pulled from the car to check it, as well as the wiring check to make sure one of them is not broken or one of the venting lines having a crack instead.
But they can also be caused by a lot of other things. Failed vent valve, cracked evap hose, cannister....
Suggest you get the ACTUAL code you are fighting, and start by researching it on the Internet.
https://www.freeasestudyguides.com/e...eak-p0457.html
If a new gas cap doesn't fix the problem I suggest you take it to a qualified mechanic. Chasing evap leaks generally requires having a smoke machine, AND experience knowing where certain cars are mostly like to experience EVAP leaks. Otherwise you can end up throwing parts at it without the light going out.
