Camaro Hood vent with E-Force
Like the title says, I was wondering if anyone here had tried installing the camaro center hood vent with an E-Force supercharger. I know that the charger is pretty low profile but it does increase height just enough that I am concerned. Don't want to butcher the hood only to find out it wont clear. Thanks
on a c6 corvette?
Yes on my 06 Z06. The ZR1 hood has a higher bulge then the regular hood doesn't it? Also I believe the ZR1 insert is slightly different than the GM camaro piece. Thanks for the input
This thread has several pictures of various installations, including a few pictures of underneath, with and without drip trays. You'll probably figure out an answer scrolling through the pages of it.
cRoe4 (03-22-2019)
scoops cant be trimmed because the grill mesh attaches at the lowest point in the scoops. unless you cut out the entire mesh i guess.
id guess scoops hand down 1.5 to 2" from bottom of hood.
i do not run the drip tray. you wouldnt even have a chance with that.
cRoe4 (03-22-2019)
I don't think you'll have room unless you place the vent pretty far forward.
I had to remove my fuel rail covers with the placement of my vent. That eforce is going to sit quite a bit higher than the fuel rail covers do.
