Kenwood DNX9960
Kenwood DNX9960
Anyone have thoughts on the head unit Kenwood DNX9960?
I just purchased a car with this stereo in it. I tried doing some research and can't find much good. This was supposed to be a top of the line unit back in 2011 but all I keep finding is negative things..... Is it that bad? I mostly just want to listen to music and rock out with it.
Anyone have imput on this unit?
Thanks!
Thanks!
Received 1,636 Likes
That unit came out in or around 2010. So the tech and design is about 9 years old. There have been some notable improvements in the double din market since the 9960 was available. But it all comes down to what features are important to you. There have been improvements to the operating system, improved screens, additional features like apple carplay and android auto, improved load and start up times and touch response, etc. If it was mine, I would probably look to upgrade. But that's me. If it's still working well and you are fine with it's performance, I say keep it. If you want to take advantage of some of the newer tech and features, it might be worth it to upgrade.
The one at the top of my list at the moment is the Kenwood Excelon DNX695S but I'm wanting it for the Garmin NAV to replace the primitive GM NAV. What is it you are looking for? It's not like CD players and car amps have really changed in 10 years.
As RedFred said there are definitely newer stuff out there, but if you are just wanting to listen to music and rock out, you should be good to go!
There are many choices out there that can cover the gambit of prices from $300 on up to $1000. Do you want built-in NAV? Do you want to be able to watch a DVD, well your passenger of course? Do you want to listen to CD/DVDs? Do you want Apple Car Play or Android Audio? Do you want a back and front camera along with many other options?
I would check out crutchfield they have a great interface to find out what fits your car and matches your needs along with everything you need to get it into your car including the connection interface and detailed instructions as well as knowledgable folks that can help your decision. You can always check out a Best Buy or similar near you to physically lay hands on a particular model to see if you like the interface.
Because this HU is quite old, it is very very slow and the user interface is quite clunky compared to today's tech.
I've been pretty happy with pioneer units for off the shelf performance (no amp/tuning). Personally prefer Pioneer over Alpine, Kenwood and Sony (these are the three brands i have bought used and regretted buying then selling off to buy a Pioneer HU).
I have both the Kenwood excellon DDX 9903 + DDX 9904 head units and both are excellent units which can be had for less than $400
The DDX 9904 works better with the later blue tooth 5.0
Just my $0.02. I purchased a Pioneer with Apple CarPlay and I got tired of having to use the cord so I ordered the AVH-W4400NEX (I didn't need/want built in Nav, so I went with the cheaper one). Wireless Apple CarPlay, which is was my most important feature.
So it comes down to what features you want - nav, siriusxm, HD radio, etc....
Have you tried doing the firmware updates? They should help bring it back up with the times.
My car came with a Pioneer AVIC-Z130BT, was their flagship receiver back in 2011 and was $1200-$1500 from what I can find. Worked pretty good with my Samsung S7 but when I upgraded to a S9 I lost BT and some other functions. Since Pioneer stopped doing updates for it many years ago, I found a forum of geeks that wrote their own updates and for $12 they sent me a SD card with all the updates, works great again and I'm back to rockin'.
Looks like yours has some free firmware updates, it's worth a try.
https://kenwood.garmin.com/kenwood/s...elName=DNX9960
https://www2.jvckenwood.com/cs/ce/mm...2010b/eng.html
That unit has CD, Bluetooth and a built in NAV.
What issues do you have with it?
thanks i will try to update
Do any of the aftermarket head units work with the OEM steering wheel controls? I'd like a nice Garmin based GPS unit with Apple Car Play and all the bells and whistles. Any suggestions?
If you want Garmin brand GPS, then look to get a Kenwood. Many find that having built in navigation is no longer necessary since Apple CarPlay and Android Auto give you the capability to use your phones navigation through the new head unit. If you still want built in navigation, you will pay a little more as you will be limited to the top of the line models.
